hi all
im selling my rb25 motor gearbox with all accessories to make way for my conversion looking at around $5500 reasonable offers concidered. may seperate if enough interest is there. all the gear is still in my car (r33) so can be heard running etc. has been slightly modified. mods are as follows!!!!!!
hyper gear tr43i turbo, kkr 3 inch dump pipe with stainless steel front pipe
apexi power fc
deatschWerks 550cc injectors
split fire coils
z32 airflow meter
front mount intercooler
extreme six sprung button clutch with heavy duty pressure plate and light weight flywheel
gizzmo elentronic boost controller
short throw shifter
sard adjustable fuel reg
thats all can think of at the moment, will also come with wiring loom as well as all piping for intercooler blow off valve . it is a series 2 motor has recently been dyno tuned at pro auto with 245 rwkw
if interested or want to ask any questions or make an offer by all means contact me on here or call/ txt me on 0408802254
cheers
jeremy
https://www.sau.com.au/forums/topic/299073-rb25-package-for-sale/
hi all
apexi power fc
split fire coils
z32 airflow meter
short throw shifter
cheers
jeremy
will part out if enough interest
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
