I think John (ISOLA) has given me some of his gremlins.....
Over the 18 months ive had my 34 a few random times when i start the car all the dash warning lights flick on and off as per normal but sometimes the TCS & SLIP lights i think, the ones at the top of the dash cluster have stayed on!
The car doesnt feel any different as such, and then if i turn the car off and start again they go away. Its like they just dont flick off sometimes.
Im wondering if anyone else has had this happen of if its nothing major to wory about or if its effecting the car only that its happened a few times now in a short time frame???
Thanks Donna :P
https://www.sau.com.au/forums/topic/299099-gremlins/
If you've got no ill effects it's most likely the TCS throttle motor, they can start to get a little sticky and play up, if it doesn't move the way it's supposed to on startup it registers as an error, with TCS and SLIP lights on.
https://www.sau.com.au/forums/topic/299099-gremlins/#findComment-4974232
Mmmmm interesting .....
If that is the case .....
1 How much do you reckon a throttle motor is?
2 Are they hard to get?
3 Are they hard to replace?
https://www.sau.com.au/forums/topic/299099-gremlins/#findComment-4974749
No idea on cost/availability. They do pop up a bit in the for sale section though. If you're not overly phased about the TCS system working 100% right, you can take out the butterfly plate (2 screws holding it) and that does tend to fix things as the drive doesn't get caught on the inside of the plenum anymore.
All your codes will appear normal, just if you do activate the TCS you get some loud popping out the exhaust due to the airflow not being cut off as before.
https://www.sau.com.au/forums/topic/299099-gremlins/#findComment-4974762
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
