Hi guys,
I would like some expert opinion, if possible, to my problem.
I'm designing a new off road racer, trophy truck, full spaceframe, independent front, 3 or 4 link rear axle, 20-26 inches of suspension travel, somewhere in the region of 2 - 2500kg all up weight.
I researched using a Skyline some 8 years ago back in the UK, but the rework on the gearbox for my design made it a non starter, now I'm out here, older and hopefully wiser and am investigating drivetrain options.
The norm is 355 chevy and a TH400 auto box, but I'm not for following the crowd....... like to push the envelope somewhat. Yeah its painful sometimes but success brings so much satisfaction.
I have been scouring this forum and many other websites, looking for answers, but having no experience in the nissan arena I thought it would be best to geti into the open and put my problem forward.
So if anyone has opinions, ideas, technical and any thoughts on the matter, i would be most appreciative.
I've attached a naked photo and a fully dressed photo so you have an idea of where I'm at.
I thank you in advance......
Nige
Yakboy
Rise to the Challenge !!
https://www.sau.com.au/forums/topic/299245-engine-gearbox-selection/
why are they so heavy?
Hi battery, the yanks build them like tanks because desert racing, baja mexico especially is the roughest terrain where the punishment on the frame and components is extreme. Their average size is some 2.2m wide, track width and 3m wheelbase, add on body work so that gives you an idea of their massiveness !!!!!
I'm not building mine to that extent because I have to go around trees and follow narrower tracks that our smaller buggies have to fit around. Mine at the moment is 2m by 3m on the outside,of the bodywork. I design for power/weight ratio and go as light as possible but not compromising on cage safety or strength where its needed.
I forgot to say on my first post that I'm restricted to 6L engine capacity, so something like a 2.8 turbo multiplied by 1.7 (turbo factor ) gives me a total capacity of 4.7L thereabouts...... but i'm looking for reliability, availability of spares, ease of maintenance and relatively cheap......
just looking for poeples ideas and opinions for a good strong engine/gearbox combo that might be able to handle what I do......
Loads of racers in the buggie classes run SR20's and they are virtually bullet proof........
Anything can be made to fit !!!!!
cheers
nige
cheers
nige
There are loads of boat and buggie motorsport vehicles utilising VH41/45 VK56 V8's. What sort of hp torque were you looking for? what sort of climate will you be racing in? If you plan running forced induction in hot climates have a good look at methanol.
Have a look at this for some ideas:
http://forums.nicoclub.com/zerothread/323706
J.
Vh or vk45de ..destroked to 3.5 litres + twin turbo's = :rofl:
Lightweight torque monster & different to the chevy option...you could use an adapter plate to mate pretty much any gearbox that will handle the punishment.
What kind of budget are you working with ?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
