Nowadays rip DVDs is becoming a common activity performed by many software programs. But many portable multimedia players only play video in the MPEG-4 format. Now, when getting a DVD ripping program is a must, the question on what to look for will be one of the first questions that you will likely ask.
If you own a portable gadget that plays video and you want to watch your DVD videos on it, you most likely need a DVD ripper program. This includes devices like the iPod Touch, iPod Nano, iPod Video, iPhone, Zune, PSP and others. If you want to store your DVD movies on your computer or a hard drive, you too need DVD ripping software.
This guide will show you how to use 4videosoft DVD Ripper platinum (for windows users) and DVD Ripper for Mac (for mac users) in an easiest way and explain how to merge/ subtitle/ crop/ trim/ effect the video files while conversion.
Part 1: How to rip DVD files into versatile video/audio formats for playback on iPhone/iPod/PSP/Zune/Apple TV/Phone/Xbox/Zen…
Step 0: Download and install 4Videosoft DVD Ripper Platinum
Step 1:Load your files
Click “Load DVD” button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2:Choose your settings
Select the output video format you want from the “Profile” drop-down list.
Some powerful functions such as “Trim”, “Effect”, “Crop” “Preference” are all available.
Step 3:Start conversion.
If you want to convert DVD by default settings, just click “START” button to convert. It is the easiest and common way to convert with only three steps.
You can have a coffee or have a walk now! In a short while the conversion will be finished.
Part 2: how to rip a DVD to AVI, MPEG, MPEG4, WMV, MOV, DivX, ASF video or WMV, MP3 audio on your Mac computer
Step 0: Free Download and install 4Videosoft DVD Ripper for Mac
When you finished the download process, run the .exe file to install it.
Step 1: Click “Load DVD ” or “Add DVD” button to import DVDs.
Step 2: Select one or more files in the list, click "Profile" drop-down button, select an output format for selected files in the drop down list that opens.
Step 3: Click "Browse" or “Open Folder” button on the right of "Destination", select a destination folder in the dialog box that opens, and click it.
Tips: If you want to do more operation with your DVD, the following functions will satisfy you.
1. Effect.
If you want to adjust the effect of your movie, please click the “Effect” button and a pop-up effect window will appear. It allows you to edit your movie’s effect including “Brightness, Contrast, Saturation and Volume”.
2. Trim.
The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the exact time-length of the clip or you can directly drag the slide bar to the position you want.
3.Crop.
By using the "Crop" function you can crop off the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices
Step 4: After all the settings, click the “START” button to start ripping DVD to destination format.
Keep these tips in mind while shopping to find the best DVD ripping software for your needs.
Video Converter Platinum
Video Converter for Mac
iPhone ringtone maker
iPhone ringtone maker for mac
FREE iPod Video Converter
So just go to have a try now.
Start here to get your wonderful experience.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
