Hey guys have a few R33 parts i no longer require.
Unused set of Aus spec Tein Super Streets, havent been used, been sitting in my garage for about 5 months, comes with all the spanners and what not. Looking for $1300
Stock airbox and snorkel $60
R34 Snorkel only $20
All 3 rear seatbelts $25
Jack and kit $20
Skyline Door Garnishes $30
Rear Skyline Garnish $25
Rhs Guard in White, no badge still has the indicator but fairly scratched up would need a spray $75
In Brisbane.
https://www.sau.com.au/forums/topic/300079-few-r33-parts/
Replied to your pm's mate, sorry i couldnt help.
Also have a 5 Speed Manual Conversion kit, with everything 5 sp g/box, front tailshaft, flywheel and clutch, flywheel cover plate, clutch master cylinder, slave cylinder and lines, pedals. Looking for $1600
https://www.sau.com.au/forums/topic/300079-few-r33-parts/#findComment-4992214
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
