as the title says i have an rb25 coilpack loom
but i need an rb20 coil pack loom, looking to do a straight swap
or also willing to sell
the rb25 loom i have is in mint condition and i will post pics to show asap
call jason 0413329084
https://www.sau.com.au/forums/topic/300082-rb25-coil-pack-loom/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
