Item: 1989 Nissan S13 Widebody Silvia
Website: Here, among others.
Item Condition: Used, but good.
Reason for Selling: Making way for a house (or a 4x4).
Price and Payment Conditions: $18,000 or $17,000 with stock wheels, no HIDs.
Extra Info: See below.
Pictures:
Contact Details: PM to arrange a viewing, more photos or a test drive.
1989 Nissan S13 Widebody Silvia I purchased it in early 2008 with every intention to race it in Time Attack, Track Attack, and motorkhanas. Unfortunately, after having reached a stage where it is now ready for the race track, I come to a crossroads in my life where selling this machine is the right thing to do. I've done less than 5,000km in it during my ownership (My daily's done 50,000km in the same time instead). The Silvia's been on stands for probably 9 of the last 18 months, having various little things done to it in-between me working full-time shift work. Below are some details on the car. It's been driven twice in the last 2 months, and before then I was away for 6 weeks in Europe. It'd be nice to see it bought by someone who'll drive and appreciate it.
Body: Approximately 110,000km on the chassis, all straight and no accidents.
45mm D-Max front and rear guards. The rear guards and sideskirts have been bolted on using stainless steel allen bolts to make removal easy (when I had intentions to race it, bog would've been a pain in the arse). Race-grade foam is under the guard edges to stop moisture and grit getting under it. Standard guards under the widebody have been modified for provision of bigger offsetted wheels and professionally welded (no pop-rivetting here!)
Bodykit is a full genuine Japanese Supermade Instant Gentleman aero kit, including boot spoiler. GTR-style grille.
Paint is Lexus Tiger-Eye Mica.
Dual-square headlights, with Kaixen low-beam HIDs (June, 2009).
Crystal tail lights, and all bulbs replaced with LED bulbs (June, 2009).
Powertrain: Stock RB25-DET from an R33 Skyline GTS-T. Approximately 100,000km on the engine now (originally 90,000km before going into the Silvia). Smooth, never boosted, blows no smoke. KTS solid engine mounts. Has had three oil changes while I've owned it, Motul 8100 Xcess with genuine Nissan oil filters (last oil change July, 2009). Replaced original sump plug with a magnetic sump plug. R32 radiator (flushed recently, has never ever overheated). ARC sidemount intercooler. Pod filter. Splitfire coilpacks replaced less than 2year ago. Mod-plated.
R33 GTS-T 5sp manual gearbox, pulled from the same car as the engine. Nice solid shift, and one of the toughest boxes Nissan made. KTS gearbox mount. Motul gearbox oil, changed in September, 2009. Mod-plated.
Clutch is an NPC heavy-duty organic item. Just bedded in, very bitey and would be able to handle a lot more power if the boost was wound up on the motor. Machined flywheel. Rebuilt clutch master cylinder October, 2008. Receipts for clutch work September, 2009.
Nismo 2-way LSD. Locks up well but is much more forgiving than many lesser LSDs. Perfect for a daily driver and a circuit car. Connected to the box via a custom tail shaft. Mod-plated.
Brakes: R33 GTS-T set-up. 5-stud hubs all-round, with 296x30mm front discs and 4pot calipers, and 297x16mm rear discs with single-pot calipers. Braided brake lines. Brake master cylinder flex-stopper. As expected from a car weighing hundreds of kilos less than an R33, it stops very very well. R33 handbrake assembly. Mod-plated.
Suspension: Tein Flex coilovers. Fully height adjustable, front camber tops (12kg springs front, 10kg rear). Rear suspension is complimented by KTS adjustable rear upper camber arms, KTS adjustable toe rods and KTS adjustable traction rods (purchased November, 2008, installed April, 2009). KTS rear strut brace. Tein in-cabin Electronic Damper Force Controller (EDFC). Makes a very noticable difference in ride quality with the fully adjustable dampers. Handling is amazing.
Wheels: Weds Kranze Cerberus, gold face and chrome dish. Fronts are 17x9+25, rears are 17x10+37.
Tyres: Fronts 215/45ZR17 Falken Ziex. Rears 235/45ZR17 Federal SS595.
Electronics: Relocated battery into boot (Federal dry-cell sealed battery, OEM for Mazda MX-5, receipt showing purchase early this year and still with warranty).
Mongoose M80S car alarm. Immobiliser, shock sensor, door sensors and bonnet sensor. Two remotes.
HKS 2-stage boost controller (never used, but the harness is in the cabin and the controller in the engine bay, only needs to be plugged in and played with).
Turbo-timer (with other functions...)
Panasonic 2DIN CD and MiniDisc player. Front splits, rear 6” 2-ways.
Electric mirrors, electric windows, power steering.
Interior: Bride Zeta II racing bucket seats on adjustable rails, mod-plated. Will also sell a pair of brand new Klippan harnesses (one box still never opened, the other opened for inspection).
Nardi steering wheel, Razo 230g gearknob, new leather gaiter, full floor carpet and mats. Still has all interior plastics. Will also sell with the car a D-Max VIP dash table (was removed to accommodate my taller passengers).
Standard S13 cluster with the exception of the R33 GTS-T tachometer. All guages work
7-point Safety21 bolt-in roll cage, all padded and mod-plated.
I think that's everything. The car is a pleasure to drive. It only ever attracts positive attention from other motoring enthusiasts, and in the time I've owned it the police have inspected it once (at Pinelands one Thursday). No trouble in it ever. I think, as a road-registered car that could be driven daily, it will make a fine circuit car. It has the right components to be competitive (fully adjustable suspension, tough gearbox, big brakes, cage, LSD etc) and given the low state of tune on the motor and the copious amount of torque it delivers, it has been reliable and an easy car to drive for the entire time I've owned it. If I already owned my own house with a triple garage I wouldn't sell it. But I don't have either of those things and I have to sacrifice my dreams of racing the car to try and achieve other life-long goals. Will sell with all spares, but not with the personalised plates.
Will be sold with a roadworthy certificate and QLD registration through to May, 2010 (but standard number plates) unless requested otherwise. Will also be sold with assorted parts I've collected since owning it.
Any questions please ask.
https://www.sau.com.au/forums/topic/300125-s13-silvia-widebody-rb25det/
Mate I'd really prefer the cash as I have my daily aswell and am trying to get rid of a car. Unless you can stump up with some cash + your Stagea, too (which is very very nice, I've seen it around a few times :wub: )
Alright people, the car isn't being driven and I'm going overseas soon, so if you're interested and want to make offers, by all means go ahead.
Will be sold with assorted spare parts, and if you want it really cheap, no rego :)
  • 3 weeks later...
  • 4 months later...
Well the car is still for sale, has had about $2000 spent on it in the last month, detailed below;
New RDA slotted front rotors, machined rears
New QFM HPX pads front and rear
All new fluids; new oil/filter, cooling system was flushed and all coolant obviously replaced, new DOT4 brake fluid, new Motul diff oil
Newer low-mile turbo and new gaskets
New stainless steel split dump pipe
QLD rego until June, 2011
JIC adjustable front castor rods
New tyres front and rear; SS595 215/45ZR17, and wide SS595 255/40ZR17
Spares are as follows;
17x7.5 R34 GT-T wheels with legal rubber (just!)
Standard turbo and dump pipe, standard front rotors
So, $18,000 is getting you something that is still getting maintained and well-cared for. Please come and see for yourself :thumbsup:
So it's with much dismay I open the door for offers on my car. Sick of seeing it in the garage not getting driven, sick of being offered swaps for iPhones and ride-on lawn mowers. I think the price is very fair but the car market does not.
I can strip some parts from the car to further reduce the price if potential buyers low-ball, and/or sell with no QLD rego. Feel free to PM with any offers or questions.
Just had all vacuum lines replaced and did a compression test on the engine, all cylinders within 6% of each other so happy days. Buyer will be buying something very reliable.
Negotiable on price.
  • 2 months later...
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
