Yeah you won't believe this but I currently have a Stock Standard ADR approved compliance Catalytic converter on my R33 and when i went for the DECC inspection (i got defected for noise levels a while ago and sent to the decc) , the guy at the DECC inspection has defected me for the cat because i dont have the compliance papers. 2nd hand owner here...
So I've been defected again for a compliance CAT!
I need some help from the good natured people on this forum, because the only one i can find the guy wants 850$ for. And i only need it for a day! Im not paying that for a cat most people throw away.
Anyway the part im looking for to get past this DECC test is as far as i know the Stock CAT for an R33 Series 2, or it also comes off a Nissan Maxima 1998 - 2001 models
The cat will have X3 or X5 stamped on the bottom of them. I can post up some pics tomorrow.
Does anyone have one for Sale, or will to let me borrow/rent for a few days, else my car gets de-registered....
Even if someone has the full exhaust system i will take that.
Call me on 0401016609, names Simon
https://www.sau.com.au/forums/topic/300384-stock-cat-r33-s2-x3-or-x5/
Thanks :cheers:
Simon,
Where are you located? I have the same problem, check my thread under NSW. I am getting an original cat tomorrow. You can have it after I pass the test. I know what pain you are going through.
Simon,
You guys just need a stock Cat from an r33?
Im pretty sure ive got one lying around. $50 plus postage if you want it. Coming from Brisbane.
Let me know and I'l Rummage through to find it and confirm for you that it has X3 or X5 on it (im at work- Cat should be at home).
PM me if interested.
Cheers
got a stock r33 ser2 cat if you want it. pm me or call 0421561681.. in gc qld
Hey guys, sorry no internet for the last couple days.
Um yes the cat was actually x4 and x5 stamped on it on the bottom (the mechanic is dyslexic apparently and told me it was x3, until off course i saw the photos and its clearly a 4), the X5 one looks more like a plate attached to the bottom of cat .
So yeah anyone with a DECC passed cat, i will take it.
The DECC guy in Cambpelltown who is apparently the best to go to has given me two photographs, it the cats dont look like one or the other, he wont pass em.
Will upload photos tomoz.
Will be PMing everyone who has replied here
i have a few adr approved compliance cats here is that what you require?? if so pm me they have flanges on the fo direct bolt in replacement
No they wont pass the ADR compliance cats, trust me i have one ont he car atm.
The DECC specifically want the original nissan parts that get taken off the car for compliance, i know it hard to understand but its the reality we seem to be faced with.
The cats have and X3, X4, X5, stamped on the bottom, some have a nissan stamp also.
If you have one that fits the above criteria PM me!
so basically they want you to return the cat to the "non adr approved" japanese version to pass a test am i getting this right?
That is correct, i have even called and spoken with the one guy responsible for approving these things at the DECC.
Greg somebody, and he is just painfully uncaring.
He will give you the following options
1. Use non standard cat and pass an RTA emmsions test
2. Get the non ADR original nissan CAT and get it passed DECC inspection
Believe me i tried to sort this out and get him to f**king see sense over this. Basically their reasoning is they can't trust mechanics or engineers or US. So unless you have compliance papers for your car, no deal. He even said if you get compliance papers now that youve been defected it wouldnt matter, you still have to go for an emmisions test again!
Good times
Pics of the required CATS
Those are the X4 and X5 cats, apparently an X3 is also passable but no photo of it.
Sorry for the horrid scans but the photos i was given are not the best quality.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
