  • complete RB26 Head out of R34 with all the cam cover(RED) around 30,000Kms
    $2000
  • Stock dump pipes $200
  • Stock Radiator $100
  • Sump&Diff(GTR33) $400
dont have picture yet will send them to your email if requires
https://www.sau.com.au/forums/topic/300505-rb26-engine-strip-parts/
pictures
Diff
Sump
12164_223888384840_510404840_2878584_4499013_n.jpg12164_223888409840_510404840_2878585_4927933_n.jpg
Radiator
Head one valve is slightly band reduce the price to $1500(including the cam covers)
Edited by kevinisagoodboy
im so sorry man...
I'm not quite sure why you didn't just PM me....but it's Xmas and in the wider scheme of things it doesn't really matter and I'm feeling philosophical and you said sorry, so no hard feelings in the end eh. Merry Xmas.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
