hey guys i have a few things for sale two r32 turbos with minimal shaft play good condistion $$250 for both.
1 rb25 turbo no shaft play in out at all a small bit side to side vey small.. $250 perfect rb20 conversion
rb25 head pressure tested and new valves all good i brought it all done was going to do a rb30 hybrid conversion $250 but cams have been left out after clearance was done and there rusted but ill chuck them in if you can fix them.
roh 18 inch mags all 100 percent tyers $650 would prefer stock r33 mags trade in as ill have no wheels and ill take $500 plus stock wheels
and some other bits and peices a complete motor pulled apart so i have a rb25 block and other bits will sell whole motor in peices includind head for $400
also i have brand new cv boots for an r32 $30 for both front ones
and an rb20 tps...i think it is it sit on the front of the cam gears with the plug underneath it $50
brand new coil packs for r33 series 1 and for all years of r32 super spark brand there red..$340
and if you after random parts off a rb25 motor and it does not sell complete all part it out cheers matt txt me on my phone if you can im not at home all the time will get pics on request.
ph:0402948881
Matt
Im after a harmonic balancer & the pulley that bolts up to the water pump.
If the price is right i will drive to Bendigo to pick up..
cheers..
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
