ITEM: Looking at Swapping my VT Calais 5.0L - Throw me some offers!
CONDITION:Used
DELIVERY/PICK UP INFORMATION: SA only
PAYMENT OPTIONS: Swap - cash adjustment if needed
CONTACT DETAILS: PM or 0418 807 844
OTHER INFO:
Hi guys,
Looking at swapping my 5.0L VT Calais.
-160,000kms
-White
-Tan interior
-Lowered on new KYB shocks and lowered springs
-Nolathane bushes
-Pacemaker extractors & full system
-20% tint (Very dark)
-LPG fitted about 6 months ago (with larger than standard converter = more performance and still under warranty)
-Extended platinum warranty (approx $1400 worth - 4.5 years remaining!!)
-Huge service just performed including: New water pump, every radiator / heater hose, heater tap, thermostat, thermostat housing, all fan / alt / AC belts, coolant, Oil, oil filter, air filter, leads, dissy cap, rotor button, platinum plugs etc etc etc. (Big dollars)
The car is pretty well immaculate, will not find a cleaner VT Calais 5.0L out there. - I know, as I looked around for months before i bought this one.
Dont be put off by it been V8 either - It cost approx $40 to fill (70L useable litres @ approx 55-58c P/L). It gets about 350kms round town, and about 450-480kms on the highway.
I dont have any pics at the moment, just google a white VT Calais, add dark tint and lower it. thats how it looks lol.
Looking for a fairly stock turbo manual skyline. (exhaust, front mount etc etc ok, but not interested in something that will never get off defect if it gets done)
Or a nice Stagea.
https://www.sau.com.au/forums/topic/301171-swap-my-vt-v8-calais-with-duel-fuel/
Hi, sorry I cant PM.
How much cash do you feel your car is worth?
I have a 1995 R33 manual with 126K on the clock.
mods include: FMIC, stainless steel turbo back exhaust, adjustable swaybars/caster, leather look interior, 17inch rays nismo LMGT1 wheels.
I may consider a trade with cash my way.
Cheers
Cheers
Mine is easilly worth 9.5-10k.
My number is 0418807844, keen to have a chat to see what you have in mind. Call or SMS me mate
HI,
sorry for the lack of contact.
I think my A/C compressor has died. I'm having it looked at today.
When its fixed we'll talk (thats if it is not gone already).
Cheers
