  • Replies 63
Posted Images
I cant speak for anyone else, but I'm hoping to do an sa to nsw roadtrip and back via vic next year during winter
most of that time is on mt hotham tho, so i dunno how many people would actually be keen - my plan would involve a drive back via the great ocean road
-D
Shoulds promising!! Hope it happens..But should come see some racing if you have the time
Jess ill be over in October need to call you about that :);)
Oh awesome!! Yep give me a ring :ermm:
Whats on around July/Aug ? Not quite sure when I'll hit up the snow - as it is the GTR is pissing me off with niggling issues so I have to make sure I got a reliable car and that I can afford to go - if I have a major problem its goodbye holiday hello rebuild heh
but I'm keen. Ive not been above Albury since I was uh 2 yrs old...
-D
I will be helping run a supersprint at EC on the 11th July. If you have a CAMS licence more than welcome to enter..There is FOSC on at Wakie on 7 & 8th August which is a huge race meetings with lots of different cars that I will be more than likely working at..A Supersprint is on at Wakie on the 15th August as well
Other than that there will be trackdays on aswell in those months
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
