i have for 96 r33 gtst, s2
Right Guard $70
Right Headlight $60
Rigt Door $70
Boot with Spoliler $80
Rear Bar $70
Rear Lights $60 pair
Front Winshield $100
Rear Winshield $100
Rear Left Quarter window $60
Rear Right Quarter Window $60
Front Seats, No tears. $150
Rear Seats, No tears $70
Dash Board, (airbags) mint condition $150Centre Consol $50
Roof Lining $70
Rear Right Top Quarter Trim $40
Rear Right Bottom Quarter Trim $35
Rear Left Top Quarter Trim $40
Rear Left Bottom Quarter Trim $35
Floor Carpet, good condition $80
i have full car so if i left something out and you need it, let me no
I will chop up the shell if any1 wants quarters, or any part of the shell, let me no
5 Stud Brake setup
Front'' right and left
Brake Calipers (sprayed red)
Brake Pads (good condition)
Rotors
Subframe
Suspension Components/no coilovers
Brake Line
5 Stud Hubs
Everything Exept coilovers
All in one piece
All bolts Included
''REAR'' right and left
Rotors
Brake Line
Handbrake Cable
5 Stud Hubs
Diff Shafts
Suspension Components/ no coilovers
Everything Exept Coilovers
All in one piece
All bolts included
$700ono
If you want pic of any part, let me no i will post it up
any other parts you need, ask i will have
Western Suburbs, Melbourne
0411980023
https://www.sau.com.au/forums/topic/301991-wrecking-r33-gtst-s2-cheap-parts/
have you got a complete shell? after a shell for a track car, building from nothing, wanting glass and doors, etc,
pm sent
Hey bud, looking for the centre console bit as I've done a manual conversion to my Stagea and want to tidy things up.
Availability? Price?
:P
:P
pm sent
hey im after both left and right hand side surrounds on the door trims to the electic windows if there in good condition cheers Morris
sold, sorry mate
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
