hey guys,
ive just joined the skyline fraternity.
previously ive owned an '96' and '05' wrx, but got a little bored with awd, now ive got an r34 gtt which ive only just bought (still waiting for it to arrive via interstate freight).
currently i live in tasmania, been here for a few years and love it.. the roads and the wrx got on perfectly well, will be interested to see how i go with the r34.
looking forward to learning about skylines and the many problems im sure to encounter, as well as contributing.
already got a date set to track the r34 in february :D cant wait.
btw, im looking for a stock r34 gtt bov as my car has a blitz unit on, its not overly loud and the car doesnt backfire or idle rough at all, however id still like to get rid of the whoosh altogether, let me know where i can find one, as ebay's dry.. will i have to go to a local nissan parts centre?
oh, also looking for an r34 gtt steering wheel?
cheers guys
Edited by BXAFTW
https://www.sau.com.au/forums/topic/302533-new-r34gtt-skyline-owner/
Welcome to SAU man...I am new too just going around to say hi to get to know peop.
I am sure members here got stock BOV in their garages to get rid off.
WTB section is awsome. unfortunately i still have stock BOV and Stock steerign wheel on my car XD.
Have fun with forume and the 34 man.
cya around
Edited by JOHNY B
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
