Hi guys and gals,
I have no idea whether anyone would be interested in these, but thought I would ask before I throw them away.
If anyone wants more info on particular issues or wants to buy any, please PM me!
Im thinking $5 each posted anywhere in Aus is fair, but I am totally negotiable!
I should also state they are all 'used' and in varying condition.
ZOOM:
Competition Special- "G-Racer"
Issue 18- "Twin Turbo SR20"
Issue 33- "Turbo 200sx"
Issue 40- "Blitzkrieg 911 twin turbo"
Issue 41- "Powerhouse! 400kw+ NISMO GT-R"
Issue 45- "SR20 RX7"
Issue 46- "Cubes Don't Count CA18"
Issue 52- "Australia's Ultimate Street Car"
Issue 60- "Brutal! 264kw Hilux"
Issue 70- "2JZ Powered Mx-5"
Issue 74- "Fighting 300"
Issue 86- "LS1 turbo Crusher"
Issue 95- "Untubbed! 8.87 sec datto"
Issue 96- "Fear Him! Murray Kifer's 'rolla"
Issue 100- "Full Tilt Supra"
Issue 106- "Jet Fighter 2JZ 180sx"
Issue 107- "True Street 10.41sec WRX"
Issue 109- "JETT Pilot 8 sec 4 cylinder"
Issue 112- "All Turbo GAS Motorsports Supra"
Issue 114- "Rotor Warfare"
Issue 116- "Return of the Rotor"
Issue 118- "Six Shooter"
Issue 120- "Leader of the Pac"
Issue 123- "Get it India 8.6 sec R33"
Issue 125- "9 sec, 630whp for under $20,000"
Issue 127- "Lexus TT Freak"
Issue 128- "SR20 Coupe Road and Track All Rounder"
Issue 130- "3.3L Six in a WRX"
Issue 140- "Racers with Rego"
HIGH PERFORMANCE IMPORTS
Special Issue #1- "Supra and Soarer"
Issue 30- "Kanazawa's Killer R34"
Issue 32- "GTS-t Twin Turbo Toy
Issue 37- "900HP Street GTR"
Issue 43- "Top Secret Supra Reborn"
Issue 59- "GTR Special #5"
Issue 62- "C-RED JZX100"
Issue 72- "RH9 Muscle- R34 GTR"
Issue 77- "Slammin 180sx"
Issue 80- "V12 TT Supra"
Issue 89- "Wide and Wild 500ps FC RX7"
Issue 91- "Sunline 580hp Matte Carbon Monster"
Issue 97- "Worlds fastest RX7"
Issue 98- "RB26 180sx"
Issue 102- "700HP R33 GTS-t"
Issue 106- "800HP R35 slayer"
Issue 110- "100% Owner Built S13"
Issue 112- "Dyno Buster 933rwkw supra"
Cheers
Chris
Edited by Yeedogga
https://www.sau.com.au/forums/topic/302744-zoom-hpi-magazines/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
