For sale: series 1 r31 skyline wagon (1986)
Asking Price: 2.5k obo
Killometer's: 146 on clock - approx 155 now
Manual or Automatic transmission: auto
Engine Type: rb30
Condition: body good, engine solid and reliable, interior good
Modifications: rims and interior - see below
Road Worth Certificate: negotiable
Crash History: shopping trolley dings only
Hey guys, im leaving the auto trade and heading back to uni so need to sell this ASAP to pay for my fees.
-1986 Series 1 r31 wagon
-auto
-white
-series 3 front bumper currently fitted
-originally brown interior but has s3 silo door cards, front seats, grey carpet. black dash and undertrays steering wheeletc.
Still has brown rear seats and boot trim
-Old Sony HU with fron AUX input that gets the job done
-elec mirrors
-towbar
-146,*** on the clock, however stopped working 2 weeks after i bought it. Ive done about 10,000kms on it since Jan last year when i bought it.
Since i bought it i have serviced it twice and will do oil and filter again before sold. I replaced all ignition components (rotor cap, button, leads and plugs, cleaned CAS) replaced all coolant hoses, thermostat housing and bypass junction thermostat, coolant temp sensor and performed full flush of radiator. Also replaced fuel filter the other day and fuel lines in engine bay and from tank/pump.
Have performed full trans flush and adjustment (new filter/gasket) and also fitted a Davies Craig cooler in series with the one in the radiator.
Replaced ISCV with a stripped and cleaned unit and new gasket.
I rebuilt the rear calipers last month also and bled the brake fluid - she now stops.
Has 15*6.5? CSA rims painted black with 70% tread all round. Ill get specs of rims/tyres later.
Overall the car is a good, reliable and solid runner. Has some pin dents and scratches but no dings and is a 20+ year old car afterall.
Comes with series 1 bumper, series 3 headlights, 6 guage dash cluster, map light, trip meter, and a spare tailshaft and any other spares i have floating around for it.
Asking $2500 neg with reg till 10 Feb 2010
StuC
0415 298 248
https://www.sau.com.au/forums/topic/302776-r31-wagon-melb/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
