Item: R34 GT-T manual coupe
Item Condition: immaculate
Reason for Selling: desprately need the space so i can restore another car
Price and Payment Conditions: $25 000 swaps or make me a cash offer
Extra Info:
im the first owner in oz
95000ks,
5 speed manual,
RB25t (neo 6) ,
17 inch prodrive wheels with good tyres,
tien adjustable coilovers,
jap cat back exhaust,
splitfire ignition coils,
adjustable boost,
blitz turbo filter,
turbo timer,
front strutt brace,
tinted windows,
pioneer cd player,
climate control,
power steer,
4 wheel steer,
traction control (on off button),
electric windows,
anti-lock brakes,
central locking,
dual airbags,
power mirrors.
drives like a go cart
Meticulously looked after, always serviced with penrite sin 10 synthetic oil, always garaged and under car cover
car is unencumbered and roadworthy will be supplied after 5% deposit paid (so i dont get screwed around again) :)
contact: [email protected] , 0427467779
Edited by wangle
https://www.sau.com.au/forums/topic/303019-imaculate-r34-gt-t/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
