Hi i have for sale a set of coilovers they were removed from my car yesterday for the option of some softer ones, they are leaking how ever i could not feel it as they are big spring rates 12kg front and 9kg rear from what i have read.
They are fully rebuildable with in australia according to just jap. There is some spray paint on them but would come off easy with some metho or the like. There is also the 2 rear coilovers where the guy i bough them off had to shave the edge of the lock washer for the height adjustment to fit his rims.
I can post these at owners expense but i dont think it would be cheap.
Thanks lars
Monotube shock absorber design
G4 Coilovers feature feature a seperate gas & oil monotube design (30% Nitrogen/70% Oil) to actively help reduce the possibility of oil leaking defects
Fully rebuildable and servicable in Australia
G4 Coilovers are fully servicable, and can be completely disassembled and rebuilt in Australia to meet your requirements. Just Jap holds a massive spare parts inventory and can supply virtually any replacement component that may be required.
Choose your spring rates
Unlike other suspension brands where you are limited to the spring rates provided by the manufacturer, G4 Racing Coilovers are available in both the factory spring and valving configuration, and custom setups tailored specifically to your application. It doesnt matter if your car is a street car, weekend circuit racer or hardcore drift car, we can provide you with the spring rates YOU want.
Lightweight 6061 Aluminium alloy construction
Our customers demand quality and durability, and G4 delivers on both counts!.
G4 Racing Coilovers are manufactured from high grade 6061 aluminium alloy with T6 for increased hardness and formed by forging for added strength, with a durable annodized finish that wont lose colour.
Teflon coated thread
G4 coilovers feature a teflon coated thread, to prevent the rust and corrosion commonly seen on other untreated shocks.
Fully Height adjustable
Each G4 Racing coilover shock absorber can be lowered to approximately 120mm less than the vehicles original ride height, and each kit includes c spanners allowing for easy ride height adjustable on-car.
Simple on-car rebound and damper adjustment
With the G4 top turning adjuster, damper and rebound can be adjusted with a simple rotation, up to 24 ways!
Each G4 shock absorber is adjustable for both compression and rebound.
Certified by 'World ARTC' - Proven race grade equipment
G4 Racing shocks are fully qualified by 'World ARTC' for million circles with no liquid leakage, and certified as race proven components.
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
