Hi all,
I see there are a lot of subs for sale in Victoria, we can't all our bass belong to them. (you probably won't get my shit joke)
Anyway.... I have a Fusion 15" green sub in the factory box, mint condition. $150 ONO
I also have a Clarion Pro 12" in a badly carpeted Square box. $70 ONO
I'm located in the scenic Penrith Valley :cool: , also working at 'GLORIOUS' blacktown :( ... pick up from either location is fine.
PM me
https://www.sau.com.au/forums/topic/303500-subs-15-12-in-sydney/
