  • Replies 50
  • 1 month later...
hmmm anyone here with a GTS4 had a problem with there AWD light? ive only ever had it turn off twice now and the SLIP light come on as usual, but will go back to normal.
The AWD light also flashes a bit on start up and i can hear a buzzing in the boot like its trying to connect. mabey its a connection problem but ive had it looked at a few times and no one can find the problem, the AWD is working as far as i know, tho i would still like to fix the problem.
Also, o0skyline0o, Do you still have any of thoes parts form you 5 stud conversion left? Better ask now that ive got the money haha. im in sydeny aswell so pick up is no problem.
ATTESA Codes - R33 Regular and Vspec
1,5 - Front right wheel sensor and circuit
2,6 - Front left wheel sensor and circuit
3,7 - Rear right wheel sensor and circuit
4,8 - Rear left whel sensor and circuit
11,21 - Front right inlet solenoid valve and circuit
12,22 - Front left inlet solenoid valve and circuit
13,23 - Rear inlet solenoid valve and circuit
15,25 - Front right outlet solenoid valve and circuit
16,26 - Front left outlet solenoid valve and circuit
17,27 - Rear outlet solenoid valve and circuit
31,32,33 - E-TS solenoid and circuit
34,35,36 - E-TS fail safe solenoid and circuit
41,42 - ABS actuator relay and circuit
43,44 - ABS actuator motor , motor relay and circuit
45,46,77 - ET-S/ABS control unit ground and circuit
47,48 - E-TS/ABS control unit power supply and circuit
51,52 - E-TS actuator motor and circuit
53,54 - Pressure switch and circuit
55 - Air bleed switch and circuit
56 - E-TS oil level switch and circuit
61 - FR and RR G sensor 1 and circuit
62 - FR and RR G sensor 2 and circuit
63 - FR and RR G sensor 1 or 2 and circuit
64 - G sensor 1 power supply and circuit
65 - G- sensor 2 power supply and circuit
66 - Side G sensor and circuit
75 - Throttle position sensor and circuit and sensor
Are you sure that is what you are getting?
Also the buzzing in the boot, sure its not the fuel pump? The only part that would make a buzzing noise around that area is the actuator for pumping the Matic-D around the diff and transfer case. Its a $4500 part that rarely breaks so i wouldnt worry.
You should get the system COMPLEATLY bleed the propper way and then new fluid in there to eliminate that option.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
