I'm after a r32 Skyline front bar.
I'm located in Brisbane south east but will drive for a good deal. I'm after a stock bar gts gts-t gtr style no aftermarket bars please unless its a aftermarket gtr copy bar. I have cash and need this ASAP. I'm also after a headlight for the passneger side. I have a 1992 r32 gts so im not sure what type of head light it is im after.
Pm me With details.
Thanks
Edited by jtole3
https://www.sau.com.au/forums/topic/303691-wtb-r32-front-bar/
dude how picky are you on the front bar?! i think i might have a gtr bar to suit gtst - its white, pretty haggard.. but might do you in the mean time..
hey man im not to fussed really just as long as it sits on properly so it doesnt fall of while i drive :S how much are you chasing im in brisbane as well
I've got a genuine 32 GTR bar and lip , ready to paint for $350, Shailer Park 0414 645 755
Brad
hey man sorry but it would be a bi** to fir on a gts I'm guessing ill wait for the reply from the other person who says has a gtr bar made for gts-t which is most probably from jassi if it doesn't go well ill definitely be pm'ing you
thanks
Might be easier to get GTR guards and my bar , look fattr at the front as well , good luck
Brad
Yeah it sounds good I've covered this topic before though and on a gts it would make the back gaurds look very very shit :S
  • 4 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
