R33 Gtr Interior F+r Seats + Door Trims F+r, R33 Carbon Interior Pieces - Dash Surround, Gearstick Surround, Window Switches, Nismo Carbon Gearknob ++
Location - Adelaide can post/courier at buyers expense
Contact - PM or SMS 0404998591 prefer SMS as don't get on here daily anymore but will try to for the next week or two[/b]
Full R33 GTR Interior in perfect condition including front and rear seats + front and rear door trims/cards. Price - $1400 Now $1250
Professionally Carbon Fibre Dipped R33 Interior pieces including dash surround, gearstick surround with excellent condition leather boot, driver and passenger side window switches, door handle surrounds complete with Nismo Carbon Fibre gearknob. The Carbon dipping with all performed by Emtech Automotive in Adelaide and cost $950 + supply of parts to be dipped. Price - $500 + your stock interior pieces (must be in excellent condition)
Brand New Genuine Nissan Plastic GTR N1 Vent only one the other went missing, cost $380 from Nissan. These have special clips and a sticky seal making installation a simple process of just cutting out a slot, peeling off the backing to the sealant and clipping in place. Price - $150 Now $80
ill buy the gear knob for $50 inc delivery?
Sorry the Carbon Interior Pieces are now sold pending payment
Im getting a lot of PM's to split some of the GTR Interior up.
I would prefer to sell whole for ease but if I had to split would sell at the following prices as it would become harder to sell the other bits on their own.
Front GTR Seats as a pair - $800 or $400 each but would prefer not to split
GTR Door Trims - $275
GTR Rear Seats - $250
Okay well I have decided to split the interior up and the front GTR seats are now sold pending payment
The following is still for sale
R33 GTR Door Trims - $275ono
R33 GTR Rear Seats - $250ono
The R33 Carbon Fibre Interior Bits are still sold pending payment at this stage
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
