basicly its a 92 gtr and has a blown rear turbo. i have stripped the turbos off in prep for a single but financially im 12mts off that happening and i dont want it to just sit there. the car is white which you will see in the pics when i get them up and the paint in in fairly good condition.
now basicly i bought the car as a project to do up so it has a few minor issues which are easy to fix and also why im moving it so cheap.
basicly the rear turbo has blown, the left headlight has stopped working and i havnt had a good chance to trace it back with a test light, the rear diff mount bush needs replacing and the car could do with a general once over. the good news is it comes with an arc cooler, hks hard pipe kit, cusco sway bars, ohlins coilovers, braided brake lines, project mu front rotors, mines boost guage in the triple din and a jjr removable steering boss with momo wheel. it also has a sony dvd player with remote screen mounted in the glove box.
im chasin 10neg post up or pm me if your interested and ill get some pics arranged.
car is located in townsville
cheers adam
https://www.sau.com.au/forums/topic/303761-r32-gtr/
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
