Model:
1989 Model
Colour:
Gunmetal Grey KH2
Changes from stock:
Pods
255 x 35 x 18 Speedy Obsessions
Haltech E11 ECU
3" Catback exhaust
Price:
$18.0k without RWC
$20.0k with RWC
Things I would like fixed/changed:
Needs new clutch (will be looking at getting that done regardless of RWC or not)
Current wheels don't suit the car IMO (I have a full set of gold Enkei NTO3's to replace the Speedy's. The Speedy's are on the car temporarily as they will ultimately go on my Maxima)
AC regassed (not really to fussed about this but can envisaged ppl quering me about this....and along with the ABS :) which doesn't leak btw)
Brisbane (south)
Serviced/Maintained:
Dan @ ERD
Hi,
This car has 76k's approx on the clock but is consistent with condition of the car's interior albeit with an Impul speedo
Genuine reason for sale so come and have a look at the car.
Please don't hesitate to contact me via email and/or pm and/or mobile which are [email protected] and/or 0420 453 475 respectively.
There are other things in the car that you might be interested in knowing about that I haven't put up, so contact me and I'll try and answer you.
More pics to come if needed.
Thanks.
https://www.sau.com.au/forums/topic/304103-r32-gtr/
significant price drop for a clean and healthy stockish gtr....
$16500 as is no rwc...you can put whatever clutch you want.
$17000 clutch fixed no rwc
$18000 w/rwc
confident that this car will make you happy :domokun:
https://www.sau.com.au/forums/topic/304103-r32-gtr/#findComment-5048860
for those wondering.
I still drive it to work and other places now and then.
It just starting to slip once I take it past about 4k rpm.
have bought clutch for it...just need for you to install (= more time + money).
that's why i was willing to go cheaper if you want to drive it away now.
anyway if you're just short of cash but have a swap item let me know what you have.
surfboards, jetskis, boat, etc preferably not another car but will consider it.
anything of significance + cash my way :(
Paul
Edited by jaxt
https://www.sau.com.au/forums/topic/304103-r32-gtr/#findComment-5053367
yes thanks s14 (tm :)) and Arkhaeon...hope that clears that up for you sneezy.
just sifting through a couple of offers from over the weekend...so put yours in guys...interest is finally gathering momentum...
will consider offers in the price range of 14-15.5k....
Edited by jaxt
https://www.sau.com.au/forums/topic/304103-r32-gtr/#findComment-5076602
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
