hey guys....been having a bit of an issue with my r33. the car randomly will not prime the fuel pump... checked power to pump-ok. ...checked relay operation- ok found when i direct the pump it runs fine. also checked sender unit/fuel pump intank harness-ok
what i did find was on the harness side of relay ie terminal 3 has battery voltage....5 has continuity to ground(no high resistance)...the switching (positive) terminal has around 5v and the grounding side has 0.4v coming through it...is that normal?
this was all checked in the non priming status...
i have also checked ecu pin out 18 (fuel pump relay) and it has almost no resistance to ground...
where do i go from here?? any help would be much appreciated..
cheers
Roy
https://www.sau.com.au/forums/topic/304250-r33-no-startfuel-pump-earth/
sounds like the relay is shot and cant withstand the current draw.
wire in a new relay triggered off the stock relay and see if that works. new relay should get power direct from 12v not old relay.
also may want to try just swap in a mates stock relay to see if that works, if you have any R33 mates that is lol (if your in bankstown i could even let you try mine)
ahh i see, interesting then.
in that case perhaps a dry joint somewhere. try wire in whole new relay triggered off the original. new wiring from pump to new relay and new relay triggered off old pump.
should fix the problem for sure
  • 2 years later...
ok...so i found that the relay switching circuit is not being grounded....when it randomly does turn on, the car starts and runs fine...does this mean its an immobiliser fault?
Mine just did this today, car was running fine last week and now car doesn't start. Call auto electrcian and he fix it. Found that there was no earth to fuel pump. What the hell. He cut the earth wire to fuel pump and got earth from another wire for now. His coming back next week to find the cause. Thinking of just running direct feed to the pump. You any one in Sydney who can do this.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
