Hi this is my ek civic you will see its in great condition when you compare and see/drive the others.its had a new gear box ,major service , new tires 80% tread, interior is in good nick, the front bar has a few chips but apart from that only thing it needs is new car matts. it has a 6stacker cd player in the boot, 17inch lenso wheels,cannon exaust. Reason for selling need to upgrade to a family car, will be interested in swapping for a nissan stagea, any questions please dont hesitate to ask , i am negotiable also you can see the add in car sales
https://www.sau.com.au/forums/topic/304540-honda-ek-civic/
bump neg on the price may be tradeing in depending on loan no offers on the price? swaps with stageas or 4 door 34s + cash?
Hi,
I have got a Autech Stagea RS260 being shipped today from Japan. stock GTR engine and running gear with lots of mod on everything else.should get to Melb. in 2 weeks then compliance.
cheers
Alex 0433878905, 0439 818008
https://www.sau.com.au/forums/topic/304540-honda-ek-civic/#findComment-5064000
  • 6 months later...
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
