Item: JDM Lucino Catalogues x3
Website: N/A
Item Condition: Excellent. All are wrapped in plastic in the photos, they have no creases, tears, etc.
Reason for selling: Don't need.
Price and price conditions: $30 each.
Extra Info: Pickup, or happy to freight at buyer's expense.
Pictures:
Lucino Coupe:
N15 Lucino 3-Door Hatch:
N15 Lucino 5-Door Hatch (inc. AWD model):
https://www.sau.com.au/forums/topic/304879-fs-jdm-lucino-catalogues-x3/
