Forsale
R32 nismo GTR build 231
1990
98,000kms
Imported in 2005 by Brisbane street machine, From what i have been told, it was previously a show car in Japan
Car purchased from Townsville in 2009 with a blown head gasket, and since being in my hands it has had its head rebuilt, and is currently regoed in SA.
Current mods:
ENGINE:
Split fire coil packs
N1 turbos,
Braded speed flow water lines
Reco cyclinder head
Tomi valve guides
hks springs
nissasn exhaust and inlet valves
metal head gasket
New head bolts
Gates timing belt
Oil catch can
INDUCTION:
KNN Pods
Bosh Z32 airflow meters with Tomi Plugs
HKS Super SQN BOV
FUEL SYSTEM:
new gtr replacement PUMP
Standard injectors with new seals
New ryco Fuel filter
SUSPENSION AND DRIVETRAIN:
Excedy Heavy Duty performace clutch (feels like twin plate)
Machined flywheel
Nismo Diff with cooling fins
New Front left and right Drive shafts
New Koni shocks adjustable all round and new king springs
18X11 Rear 18x9.5 front WORK VS RIMS
Drilled Rear Brakes
Nismo extended wheel studs in front
MISC:
Apex'i Power FC with hand controler (also have a brand new power fc not fitted)
Nismo 320 dash 98tho on the clock
nismo steering wheel
Full nismo body
3 inch exhaust
Interior in good condition aircon in good working condition
Paint in good condition
New front bar
Stainless intercooler pipes
Oil cooler ( Not hooked up)
No rear wiper
No ABS
Nismo build number 0231 1990 model
have receipts for work done in SA
I Bought the Gtr in 09 with a blown head gasket, and since have had the engine pulled out and rebuilt the head. While the engine was out I had it checked out and had the valves and pistons check, as I was told the engine had previously had the timing belt come off. These were fine and the rest of the engine was fine. I also bought a new Brand Power FC for it, but didnt need it, but may throw it in for extra if buyer wants. The bad about the GTR is that it seems to have an electrical fault within the engine, (i believe its either the AFM or Oxygen sensors, or both, but havent yet fixed this due to being short of cash. I dont believe it is anything major as it isnt the ECU and the engine and head are fine. Has all the symptons of electrical. It is currently tuned down because of this, and is running a bit rich.
My reason for selling is that I would like something a bit newer and possibly four door, and havent currently got the time to spend fixing it. As i say i believe its the AFM or something else electrical so would not be a big job. I also have another car and the GTR tends to not get driven much. Would also be keen for a swaps in a 34 or jzx100 or if something else nice comes up i may be interested.
From what I have been told and researched this is a nizmo GTR (500 made)
The differences in this to a normal GTR is that it has no ABS, No rear wiper, Boot lip under spoiler, Nizmo dash (320km), Nizmo diff with cooling fins, N1 Turbos, Nizmo body kit, Nizmo carbon fibre lip on bonnet, cup holder between front seats,front bar is a nizmo bar, (all of these suggest that it is a nizmo GTR)
My Asking price is $21,000 as is,
or....
$19,500 without the new Power FC and with the old one fitted,
$16,500 without the Works VS rims and without the new Power FC
am open to offers and and swaps, but am reasonably firm on the price...(if i do not get what i am after i will just keep it and fix the electrical problem and drive it myself)
Inspections welcome, serious people only please,sure to impress.
best to contact Elijah on 0419837474 (dont hesitate to throw an offer at me, im only going to say yes or no, no harm in asking)
https://www.sau.com.au/forums/topic/304954-r32-nismo-gtr-bayside-blue/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
