Hey all its time to sell my car, house is near completion and the some funds for the house!!!.
It’s a 98 sti type RA reshelled in a my95 body. (Paperwork available)
Steel mica blue
130, xxxx kms
SPECS: driveline and handling
Motor: 98 EJ20 J-Spec (STI type RA) 2.3Litre Stocker motor kit, Fully forged internals (forged crankshaft, rods and pistons),
[Engine was built by previous owner]
Motor had done aprox 30,000kms since built] Motor Runs perfectly.... any tests welcomed
Always service every 5000kms by me and always used ULX-110 oil
MOTEC racespecs computer (tuned by Shaun at boostworx)
550cc injectors,
NGK Spark Plugs
Walbro fuel pump
Blitz pod filter
Turbo smart adjustable blow off valve
Hybrid front mount intercooler
Spitfire coil packs
TD04 turbo (stock turbo)
3” turbo back exhaust (no cat)
After market dump pipe
Strengthened first and second gears.
Exedy heavy duty clutch
APEXI adjustable suspension all round
Front slotted brake discs
Adjustable sway bar
Apexi AVCR (black) boost controller
Apexi boost gauge
HKS turbo timer
17 inch speed line gold rims 70% tread all round (few gutter marks)
ITERIOR:
Nardi steering wheel
Leather seat front and back
Alpine DVA-96ie head unit. DVD receiver
Alpine V12 amp
Twin kickers sub (custom box)
Kicker amp for speakers
DLS speakers
Clarion TV
EXTERIOR:
Carbon fibre bonnet
Angel eyes headlightsno
Smoked front indicators
Smoked side indicators
Rear altezza carbon fibre look rear lights
Type D front bar?? From viva garage
Fog lights removed
Dark tinted windows
STI wing
Fully debadged
Car is currently running at 180kw at the wheels with stock turbo,
just whack on a bigger turbo it will easily make 230-250 kilowatts at the wheels no problems.
Engine can probably handle up to 300kw
Price drop $15,500!!!!!!!!! o.n.o
0424177447
Please call if you would like to have a look. No timewasters and tyre kickers please
willing to do swaps but only with cash my way as i need money!!!
https://www.sau.com.au/forums/topic/305959-subaru-wrx-gc8/
I don't recall the 98 sti RA coming with a TD04 stock.
or is that typo?
I also don't recall EVER seeing a TD04 produce 180awkw.
TD05 is it?
or VF series?
What was done to the box to "strengthen" gears 1 and 2?
did it get the RA diff ratio?
Edited by GTST
https://www.sau.com.au/forums/topic/305959-subaru-wrx-gc8/#findComment-5064795
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
