Hey all its time to sell my car, house is near completion and the some funds for the house!!!.
It’s a 98 sti type RA reshelled in a my95 body. (Paperwork available)
Steel mica blue
130, xxxx kms
SPECS: driveline and handling
Motor: 98 EJ20 J-Spec (STI type RA) 2.3Litre Stocker motor kit, Fully forged internals (forged crankshaft, rods and pistons),
[Engine was built by previous owner]
Motor had done aprox 30,000kms since built] Motor Runs perfectly.... any tests welcomed
Always service every 5000kms by me and always used ULX-110 oil
MOTEC racespecs computer (tuned by Shaun at boostworx)
550cc injectors,
NGK Spark Plugs
Walbro fuel pump
Blitz pod filter
Turbo smart adjustable blow off valve
Hybrid front mount intercooler
Spitfire coil packs
TD04 turbo (stock turbo)
3” turbo back exhaust (no cat)
After market dump pipe
Strengthened first and second gears.
Exedy heavy duty clutch
APEXI adjustable suspension all round
Front slotted brake discs
Adjustable sway bar
Apexi AVCR (black) boost controller
Apexi boost gauge
HKS turbo timer
17 inch speed line gold rims 70% tread all round (few gutter marks)
ITERIOR:
Nardi steering wheel
Leather seat front and back
Alpine DVA-96ie head unit. DVD receiver
Alpine V12 amp
Twin kickers sub (custom box)
Kicker amp for speakers
DLS speakers
Clarion TV
EXTERIOR:
Carbon fibre bonnet
Angel eyes headlightsno
Smoked front indicators
Smoked side indicators
Rear altezza carbon fibre look rear lights
Type D front bar?? From viva garage
Fog lights removed
Dark tinted windows
STI wing
Fully debadged
Car is currently running at 180kw at the wheels with stock turbo,
just whack on a bigger turbo it will easily make 230-250 kilowatts at the wheels no problems.
Engine can probably handle up to 300kw
Price drop $15,500!!!!!!!!! o.n.o
0424177447
Please call if you would like to have a look. No timewasters and tyre kickers please
willing to do swaps but only with cash my way as i need money!!!
https://www.sau.com.au/forums/topic/305959-subaru-wrx-gc8/
I don't recall the 98 sti RA coming with a TD04 stock.
or is that typo?
I also don't recall EVER seeing a TD04 produce 180awkw.
TD05 is it?
or VF series?
What was done to the box to "strengthen" gears 1 and 2?
did it get the RA diff ratio?
Edited by GTST
https://www.sau.com.au/forums/topic/305959-subaru-wrx-gc8/#findComment-5064795
    • I do like the look of these things (minus the ugly flat top surface with the text) https://rajabracing.com.au/product/nissan-rb25det-neo-intake/ Retains the OEM bottom runners, for that phat low range. If you want response king, maybe go with the Plazmaman pipe work, here's my old setup from a decade ago
    • Torque will suffer greatly, will try and find dyno difference on r34 with gt30 between stock and plazmaman short runner. like 2000-3000rpm power rdip at least. EDIT Green line is stock manifold, others is plazmaman short runner I also had a rb25 with greddy and q45 TB back in the day and was shit daily driving. Plazmaman top plenum with stock runner and DBW made it so much nicer.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
