Item Summary: R32 GTR 570hp at all 4s or 430kw
Condition: Used
Reason for Selling: down grading
Asking Price: $36,000
Delivery Methods: PickUp
Contact Info: 0412299653
Extra Information:
10 sec street machine
570hp at all 4s or 430kw its a crazy car hits hard and just insane power for a street car
only done about 4500ks on new engine coast $30k alone just for engine have recipts for $80,000
full race os giken box race fuel system the works serious car please no time wasters PLEASE
prob so so much more but if you want more info just ring or pm me any questions
will trade for a nice luxury car
quick vid on the build
CP PISTONS AND RINGS 86.5MM
EAGLE RODS
TOMIE FULL METAL GASGET SET
TOMIE OIL PUMP
ATI BALANCER
ACL RACE SERIES MAIN AND BIG END BEARINGS
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
TRUST SUMP EXTENSION
HKS FUEL RAIL
SARD FUEL REG
HKS 115MM THINK INTERCOOLER
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
TWIN PLATE 800HP CLUTCH
also just in the last 5 weeks new brembo brakes all round
$2500 worth of goodies under the car sway bars front and rear adjustable camber arms lock bar and more
has 4 spare semis slicks 95% tread paid $2000 for them did 5 laps
OS GIKEN 1-5 gear set with strong inmput shaft
full race fuel system
everything mod plated brakes turbo fuel system batt in boot comes with 6mths rego
https://www.sau.com.au/forums/topic/306877-r32-gtr-570hp-at-all-4s/
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
