hi everyone i am selling a vielside front bar and skirts i have also got
a set of r33 gtst factory wheels
a s2 r33 factory spoiler
r33 gtr factory cams + springs
safc blue screen
factory coil packs
Reason for sale:im sick of seen these parts in my garage got no space to do anything.
if you need pics of the rest of the parts just let me know and ill post them up
Located in melbourne call or text if interested 0423967556 or 0432062780
Edited by perry_r33
https://www.sau.com.au/forums/topic/307565-bodykit-and-parts-up-for-sale/
sorry guys forgot to put prices up
wheels $200
s2 spoiler $100
gtr cams + springs $200
safc $200
standed coil packs $100
vielside front bar $200
veilside side skirts $150
safc blue screen
factory coil packs
are still available
