1986 Chevrolet Camaro 305, 5.0l v8 / 650 holley carb / turbo 350 auto-transmission
currently not running has just being brought out of storage was serviced and running well before being placed in storage in 2007
body is a bit untidy so is inside 2 small dents previous owner made a mess of the wiring but still works ok comes with both original wheels and 5 spoke mags brand new front shocks lowered king springs new front calipers and pads/rotors new alternater installed before storage. the reason the car is not running is a shorted ignition modual a replacement is en route comes with new battery
$7500 for the car $2000 for the prestige plates not seperating unless I have buyers for both
or $9000 for the lot
phone or msg me on 0402541705
pictures**
http://www.carsales.com.au/used-cars/priva...0&D=7781580
https://www.sau.com.au/forums/topic/307762-1986-chevrolet-camaro/
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
