Hi guys,
I'm selling my V8 soarer and own the car for nearly six years and is my daily car.
Car done 235,000 kms and rego expired on June 2010
I do around 500km just for work and the kms are mixed of freeway and city driving.
Full tank i can do over 600km.
Here are the the list of what the car have and done:
Everything Limited have but no Air Purifier, Sunroof, Traction Control and Heated Seats.
Modifications:
- 97 Side Skirts
- 97 Tail Lights
- Bilstein Shocks
- Blue Neon in foot wells
- Blue, Green, Pink, & Purple LEDs in Gear Selector
- Carbon Fibre Soarer Pillars
- Cools's Corporation Rear Roof Spoiler
- Cruise Control De-Limited
- Crystal Soarer Clear Indicators
- LEXUS Triple-Beam Washer Nozzles
- Maltech Cold Air Fibreglass Induction Kit
- Maltech Stainless Steel Braided Brake Hoses
- MiNes ECU
- Mongoose Car Alarm / Immobiliser
- Philips Blue Vision parker Globes
- Philips Premium +30% for high beam
- Philips Premium +30% for low beam
- R-spec Data system Tv Kit
- Rush Headers standard size 1 5/8", 2x resonators, 2 x Steel core Hi Flow Cats, 2.25" X-Pipe, straight through mufflers + tips
- SuperCharge 760 CCA Battery
- Supra springs
- Tinted windows
- Torsen LSD
- Toyota Premium Horn Kit
- TRD Sports Air Filter
- TT Front Brakes with Lucas TRW pads
- Vlad's EMV audio & FM radio conversions
- Viscom DVD player
- White LED Interior & Map lights
- WhiteLine Swaybar Blade Adjustable - Front + Rear
Repairs To Date:
- All belt pulleys and bearings replaced
- Blinki Dash Fixed with bottom Blue Dash
- Cd stacker fixed & laser re-alignment done by Damian Ware
- Daryl Demarte's reconditioned Door Hinges
- Door Trims reparied
- EMV repaired by Mark Paddick
- New Air-Con Compressor with R134a Gas
- New boot struts
- New Engine mounts
- New Hand Brake Cover
- New Front Lower Control Arms
- New shift soleniods + flush transmission
- New transmission mounts
- New Radiator Overflow Bottle
- New Radiator Overflow Sensor
- New Serpentine Belts
- New Iridium Spark Plugs + leads
- New Timing Belt, New rear trailing arms lower bushes
- New Water Pump
- Repaired radiator top tank.
Car always serviced by Sport & Luxury Cars.
Also recently changed the tyres with Bridgestone Turanza ER30 and have the updated TT wheels.
Paint condtion are good except there are some stone chips on the front bar and on the bonnet.
Will upload some photos on weekend.
Want $11,000 ono
If interested email me on [email protected]
Edited by Son Gokou
https://www.sau.com.au/forums/topic/308637-fs-1991-soarer-v8-ltd/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
