Hi
am about to start shopping for a GTR this weekend :(
I understand GTR's come with T28 turbo's but not all models are ball bearing units.
Can anyone pls shed which which year models had the old school T28's and which ones came with the ball bearing versions of the T28?
Also, what sort of "flaws" should I look out for or common faults with the R33 models?
Any advice would be much appreciated.
Thanks and Happy New Year all.
- M
https://www.sau.com.au/forums/topic/30897-which-turbos-on-r33-gtr/
Hi 8thSIN,
all I can say is "Good Luck" in finding a half decent GTR. The only thing I would reccomend is getting it checked out by "Someone who really knows" not just someone who thinks they know.
By the way, I think Gerald from ICE Performance is selling his Series 1 GTR Vspec.
Hi
am about to start shopping for a GTR this weekend :P
- M
I was of the opinion that 33GTR's came with the same ceramic bb turbos. The exception is the n1's which have steel wheel n1 turbos.
As for flaws, well the early 33's have been around for a while. Things like the rubber hoses & pipes in the engine bay get frail and brittle due to heat and age, as well i have seen AFM's become faulty and lean out one bank. Coils can become faulty as well as fuel pumps. Origional kilometers also becomes a problem as the japs love to wind back the clock. Remember this can happen to any and all cars that are becomming older. I dont think there is too many common flaws though, just basic maintenance and attention is required.
Gerald from ICE Performance has an absolute immaculate R33 GTR for sale. This was/is his personal car and is a real stunner. If you are serious about finding a good car at a great price call him on 9512-7591 or 0414-359-888
thanks RedR32. I was under the impression that some early model GTR's (maybe R32's??) came with non-bb turbo's then the later models were updated with ball bearing units. I know that the R32 GTS-T's came with ceramic wheels instead of steel making them frail with anything over 13-14psi.
pity about the "winding back the clock" issue.. yeh I know it's one of their favourite past times, but I hope in finding a late model GTR, it might be more "believable".
Call Gerald. Its midnight purple, stock (except for exhaust) origional kilometers and never crashed. That is guaranteed. Just take it for a spin and you will see im right
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
