Car- black 1999 series 2 stagea 120000kms
mods- 3" cat back hks hi power, jjr 3" dump, empty cat case, split fire coil packs, jjr stealth intercooler kit, k&n panel filter, 18" pdw black fusion wheels 18x8 front +35 rear +6, 10000k HID bulbs, full set of Tokyo nissan motorsport floor mats, stagea boot mat, turbosmart stealth type 3 plumback bov, turbosmart stealth boost t, exedy heavy duty clutch( 3monhs old), timing belt and water pump done at 100000ks
Reason for sale - I don't really have a reason.
Price $20000
location Ipswich
contact info 0413533586
Pics up soon( im writing this on my phone)
https://www.sau.com.au/forums/topic/309076-1999-stagea/
  • 1 month later...
yes i know im asking too much but it owes me more and im sick of having such an unreliable car, would suit someone who actually wants to spend the money to get some power/reliability out of it. i never should have bought a nissan i should have stayed with toyota. nothing but problems since i boughit, even the drive home was a horrible (never buy an import at burleigh heads incase you deal with the company i did).
some one make an offer i need a daily driver.
https://www.sau.com.au/forums/topic/309076-1999-stagea/#findComment-5186898
prob not the best way to sell it dude. what exactly has gone wrong?? and what has been repaired or replaced??
https://www.sau.com.au/forums/topic/309076-1999-stagea/#findComment-5187298
swap my ek civic with hsd coilovers and so on
d16y4
extractors
new 2 1/4 exhaust with drift cannon NO FART NOISE
pod filter
hsd coilovers
front and rear camber kit
haylo headlights
carbon fiber tail lights
clear indicators
custom door inserts
custom shift boot
custom boot install
eclipse cd1000 head unit with splits in the front and 6x9s in the rear
duel cigarette liter ports IE IN THE BOOT
[/size]
Pictures: soon
Contact Details: andrew on 0410649166
or email [email protected]
edit
books are with the car it has nothing wrong that i am aware of wrong with it has the tipical shoping center thumb nail dings and one little larger one the size of a golf ball about 4 mm deep that i am willing to fix and its done aroung the 230xxx kms
would be good if i could post but the admin guy is being gay
This post has been edited by ajc_r33: Mar 31 2010, 09:42 PM
Attached thumbnail(s)
Reduced 96%
3648 x 2736 (2.49MB)
Reduced 96%
3648 x 2736 (2.47MB)
Reduced 96%
3648 x 2736 (2.44MB)
Reduced 96%
Edited by morehp2go
https://www.sau.com.au/forums/topic/309076-1999-stagea/#findComment-5187355
list of repairs - coilpacks - bought splitfires, exhaust blocked - bought hks hi power cat back and jjr dump, intercooler cracked - bought jjr stealth cooler, hids were stolen at compliance - reinstalled them, clutch went - installed exedy heavy duty, brake pads died - replaced them, hit 100000kms - did the timimg belt and water pump, boost control stopped working - installed boost t, bov wouldnt stay closed - installed turbosmart type 3 with adapter/plumbback kit, battery dropped a cell - bought a new one, insurance required an imobiliser - installed one, stock rim wouldnt hold air - bought 18's.
the only thing wrong now is its got camber but thats standard, in all its not a bad car
there is nothing wrong with the car now, i just dont want to be owning it when something else goes wrong.
pics of swapable cars to horne_steven at hotmail dot com
https://www.sau.com.au/forums/topic/309076-1999-stagea/#findComment-5187423
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
