Is it correct that R30 Skyline Lower Control Arms don't have replaceable ball joints???
I have a couple of R30 ones that I need to get lengthened to give me 2 1/2 degrees negative camber. I stuffed the boot for the balljoint seperating the steering arms.
I have now been told that the ball joints aren't replacable, so what I need to do is graft the outer end of an R31 lower control arm onto the inner end of an R30 one.
Anyone got a couple of R31 LCAs lying around that they would like to donate to a purebred race car like only an MR30 Hatch. can be???
Apparently R31 Steering Arms are good as well as they are shorter and therefore speed up the rack, if anyone has some...
Cheers,
Daewoo
Buy new R30 arms for about $70
And lengthen them each time he wants to replace the ball joints?
Hey, Daewoo. Are you going to rose joint the inner end too? In that case, you don't need to graft the inner end off the R30 arm onto the R31 arm. That will give you fine adjustability in the length (to the tune of about +/- 5mm to be safe). Just put a big fkoff motorsport bearing in there (3/4" works well - wouldn't go too much smaller). Might need a sleeve for the inner pivot though.
I guess $70 isn't too bad, but still almost 33% of the value of the car :huh: ...
No rose jointing or anything, I don't need it to be adjustable... after years of cars with adjustable suspension, my experience is, I, and most people never adjust it anyway once they get to a setting they like... I like the idea of grafting an R31 LCA on if that would allow me to change balljoints when needed... I would probably be happy with just a new boot for the balljoints that I screwed... the ball joints both seemed OK...
Cheers,
Daewoo
Correct - no adjustment needed after you set it up to your liking. However, unless you jag it, or know from previous experience, how will you know when it's right? It took me about 3 changes to finally get the front end of the RX2 the way I liked it. After that it was set and forget tho, and I totally agree with you there.
Sounds like a moot point anyway - doesn't sound like a big budget track weapon you're building there.
Do you mean the rubber boot that goes over the ball joint? You can buy them in assorted sizes from any parts store, or a suspension specialist for more precise fitting sizes.
I appreciate the info, and I will see if I can get just the boot...
You are right, this isn't any big budget racer... I have a $30K Pulsar Rally Car sitting unused 'cause I don't have the money to move it forward, and it isn't worth anything to sell... this is the $500 beater that needs to take a kicking and keep asking for more :cheers: ...
Daewoo
More info on the pulsar please :P
FWD or GTiR?
Trying to find a new rally car is proving very difficult. Am even considering going to the "dark side" (FWD) as good RWD cars are very thin on the ground, and generally overpriced (seems all the cashed up midle aged rally nuts are reliving their glory days and paying top dollar for all the old classic RWD rally cars :P )
More info on the pulsar please :(
FWD or GTiR?
I thought that must be you from BMSC... can't be too many 'warps' around...
N15 - i.e. FWD only.
I bought it as a rally only import it in '97 after I won the under 2L 2WD state champs in my 1600...
$8000 at the time for a damaged front and rear 1500 Auto was a good price, imagine what you could get for that money now :P
Converted it to an Aus delivered 2L manual, but then was convinced by Lee Petersen that I had to use a U13 Bluebird gearbox which turned into an engineering nightmare... meant changing the uprights, also had to change the rear hubs, spacers machined, gearbox mounts all moved, driveshafts shortened, now the steering is all f^cked up because the steering arms in the front hubs are much longer... and you can't get an LSD for it, which you could for the smaller standard GB...
Finally got it all going and blew up the engine first khanacross... trying to use the 1500 radiator... bought and fitted a new engine but haven't had it tuned again... Wife, kids, mortgage and long work hours just mean nothing ever gets done...
It does have Autoronics, Proflex and a log booked Chrome Moly Cage built by Hyundai Ralysport before they closed down...
These days don't have the money to use it (wouldn't be any good for much other than rallying i.e. fast but not sideways for fun, and rallying is just too expensive these days), so can't be bothered spending the last few $1000 it would take to get it ready for competition...
It owes me a shedload of cash and costs me nothing to keep in the mates chook shed, so I don't see the sense in selling it for a pitance which is all a 95% complete, untested, undeveloped, unproven car would fetch...
You are right about all the RWD cars getting silly money... and even if you buy one, the cost of parts is silly... that is why I like the R30... IRS so it gets good traction, all the right Datsun driveability and reliability (unlike the R31s I play against in the State Khanacross Championships), and cheap as chips... only thing is, when I was playing with Datsuns, everyone had bits they would give and swap, and the wreckers had heaps of cars to give stuff away to competition guys... now days, I don't have those sorts of contacts....
The excel series seems like a good thing, but it will only be a matter of time before someone starts throwing 10s of thousands at it like the did with the Gemini Series and f^ck it for everyone...
Cheers,
Daewoo
I bought some Dr30 Balljoints from datsport...Came in the Mail yesterday
Ummmmmm ................ how you do that?
The ball joint in R30 lower control arms is pressed in & not replaceable and the only replacement Datsport does is for C210.
What did you get for your money?????
D
Why is the DR30 BJ non replaceable? Is it because it's press in, or some other reason? All the early RX Mazdas had press in ball joints, and these are readily available. I would think that if you can press the old joint out of the arm, then you would be able to fit a new joint.
Daewoo - yeh I've been struggling with what sort of rally car to get. I don't want an AWD, as then I'd have no excuse for being slow. I sold the RX2 through frustration at trying to keep a nearly 40 year old car reliable, although I actually had it running very well by the time I sold it. That's why I was toying with building a GTSt. I had thought of a Silvia, but they are becoming more common, and within a few years I think they'll be like 1600's.
Thing is, to build a GTST will cost me near on $30k (by the time I use good quality stuff) and for that money, I can buy a very competitive EvoRex.
At the moment, a tarmac car appeals, and I'm giving serious consideration to an FD RX7. These are a great starting point, and for minimal mods are almost unbeatable on a race track. The guy I bought the RX2 from built an FD rally car (which now resides in Cairns) and that thing is a weapon on dirt too.
Decisions, decisions.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
