Item Summary: Work Ewing 17x8.0 +5
Condition: Used
Asking Price: $1200
Delivery Methods: Pick Up
Contact Info: PM
Extra Information: I have a set of rims for sale. Specs are as follows:
- Work Ewing
- Front & Rear: 17x8.0 +5 offset
- Stud Pattern: 5x114.3
- No tyres
Asking price is $1200 but this is negotiable if the right price is offered.
I'm not interested in swaps so please don't ask.
Rims can be shipped at the buyers cost.
Edited by PE42CY
https://www.sau.com.au/forums/topic/310366-rims-work-ewing/
  • Replies 41
Posted Images
not the best lookin rims
You think you have any say in here?
These are good quality, good size/offset and look good in some people's opinion so keep your useless comments to yourself. :mad:
https://www.sau.com.au/forums/topic/310366-rims-work-ewing/#findComment-5119713
  • 1 month later...
  • 3 weeks later...
@Raysboostin - I can get pictures of the backs of the rims, no worries. What I can't do is guarantee that they will clear R33 GTR Brembo calipers. I can give you the dimensions of the rims, which are 17x8.0 with a +5 offset and tell you that they clear standard BA Falcon rotors with R33 GTS-T calipers on the front of a Toyota Cressida MX83. You will have to do some research to see if they will fit. I can send them to QLD, no worries.
I couldn't PM you as I had to have a minimum post count of 10 to send a PM. Which I don't have.
I hope this helps.
Regards,
Cameron.
Edited by PE42CY
https://www.sau.com.au/forums/topic/310366-rims-work-ewing/#findComment-5209921
  • 3 months later...
  • 7 months later...
