T518Z
CWL = inducer 50.5mm, exducer 68mm.
TWL = exducer 49.1mm, inducer 56mm.
COMP HSG =
EXH HSG = 10cm2
gt3071r
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63
Compressor
-Wheel: 71mm w/ 56 trim
-Housing: .50 ar
Its a toss up between these 2, its obvious the gt30 will make more top end power.. but lag factor also comes into it, what do you guys think? Will there be a huge difference in lag between the 2 turbos? ( If you have a 3071r with t28 shit in it dont want ur reply :D )
https://www.sau.com.au/forums/topic/310644-t518z-10cm-vs-gt3071r-63/
cheers status! much appreciated... also list what supporting mods on each etc.. plans are fresh s15blacktop, 740's, z32, power fc, and either the 8 or 10cm t518z :down:
i reckon i have the same car with a 8 and 10 back to back. will check.
If you can't bear GT28 based turbos you'll have to toss the OE exhaust manifold anyway if you want it to work properly .
HKS have T25 flanged GT30 turbine housings available but not in wastegated form , the 0.73 A/R one seems to be the pick on SR's .
Actually thinking about it in the States people used to get std SR exhaust manifolds and weld on mounts for external gates , could be the cheapest way to get a GT30 based turbo onto an SR20 . They sometimes picked on the GTiR std manifold because it was supposed to be the best of the factory ones - slightly larger internal passages .
I know it was a transverse engine manifold but maybe it can be made to work .
I'll see if I can find the link to the 52T GT3037 fitted to an early Sentra SE/R in the US , it has pics of it and the 0.73 A/R T housing . The fabbed manifold is something else on whats mechanically a FrWD Pulsar .
A .
interesting read disco.. was originally planning to go the hks 3037 route, but always thought lag mite be an issue? and from reading alot of good results with people using the t518z making ~260kw mark while keeping good response. So in that case, i gather your preference would be the hks 3037 0.73 a/r? i also thought, that the t2 flange would become restrictive when chasing big numbers? or do t2's with 0.73 and SR's make a realy good combo?
T2/T25/T28 mount flanges are the same size , the generic rectangular Garrett one I mean .
Do you have a power number you are chasing ie 260 Kw ?
From what I read GT3037's can be responsive on SRs but the manifold has to be a good one and the turbine housing size right , they like the 0.73 A/R one in the States .
I reckon the earlier non VCT head and the GTiR's quad throttle inlet manifold is the go , similar situation with RB25 and RB26 with the 26 being better . Expensive but goes bolt .
I must have more faith in GT28 based turbos with the larger 0.86 A/R turbine housing than you do , I really liked my GT2860RS 0.86 on the FJ20 I had years ago . Not what you want to hear but better cams and the 48 or 52T GT2871R would be much simpler to set up .
Your call but but I think it wouldn't be too difficult to end up with a GT30 based turbo and a laggy engine , the right bits are expensive and you don't have too many areas to go back to if the lag was unacceptable . The smallest GT30 turbine housing I know of is the 0.61 A/R HKS T25 (22/25/28) flanged non waste gated one . If you were going to go that small its hard to see the point of the largest compressor trim GT3037/GT3076R .
Only you can know what power level you're chasing and how much cash your prepared to burn getting there . I find that if you don't aim too high you tend to end up with a good all round result . IMO a strong mid range is where its at in a road car at least .
Individual throttles make for really good throttles response and better cylinder filling off boost . Most SR people won't do this because they baulk at the cost and prefer to sink money into big laggy turbos on fabbed manifolds with external gates .
The GTiR made significantly more power than the "ordinary" SR20 DET's and all it lacked was a more modern turbocharger . They had an orphan T300 bush bearing sort of thing with a turbine that was 10 bladed in from memory 79 trim and I cant remember what sized GT28 style turbine housing . I really can't remember but didn't they make 187 odd Kw std ?
IMO make it breathe , remove the flow restrictions and you may not need as big a turbocharger as you think .
Same old same old , budget - how much power and starting where and how is it driven most of the time .
A .
I just found something interesting whilst looking into something else .
If you look at the turbine map for the GT2860RS 0.86 A/R its not that different to the real GT3076R's one in 0.63 A/R .
This doesn't necessarily mean that the turbine response would be the same with both turbos but it does give an idea of what sort of exhaust gas flow potential that GT28 76 trim turbine has in the larger 0.86 A/R T2/25/28 flanged turbine housing .
Since you can buy the GTRS (GT2871R 52T) through Garrett with the correct compressor housing for an SR20 , the one HKS uses , and very likely option the 0.86 turbine housing which bolts to your exhaust manifold at the same time .....
Cheers A .
well mainly aiming for roughly 250-270kw, but dont want to be pushing to much or leaning out, as i will onli be using bp98... im still stuck on the t518z?.. as a few people have gotten decent numbers about the 250kw mark... but then, if you say the 3037 .73 a/r is not much difference in lag factor, but has the option to push more power, .then that turbo could be the possibly pick.
as mentioned, only want around ~350hp... street car, but occasional track days...
also, what cams would you recommend to make the most of ; a) t518z (8cm or 10cm)... b) 3037s 0.73... is there any benefit in mix and matchin cams, (ie. 256/64 or 264/272) ... and how much lift is beneficial to the goal i am aiming?
only want a fairly responsive turbo with a boot til redline, as current setup with power fc, t28bb, fmic, pod, fuel pump, exhaust - doesnt lose by much to a few sr's running gt3071r's 0.64 and 0.86s doing 330+? ... which i find weird?
Generally these GT3071R's with T25/28 flanged turbine housings are not using the full sized GT30 turbine , they use the cropped ones .
If you go to the turbobygarrett web site and look at their turbine maps their efficiency percentages are lower than you get with a GT30 turbine in a GT30 turbine housing . Croped or full sized GT30 turbines are a bad match for a GT28 turbine housing , more heat more restriction and lackluster performance . They would be better off using a GT2871R 52T/GTRS and experimenting with the Garrett 0.86 A/R turbine housing , its only available in T25/28 flange which is what SRs have std .
Maybe you should ask around and find out what results people have got from the RB specific GTRS turbo or even the GCG Hi Flow with the larger VG30 OP6 type turbine housing . 250 260 at the treads is a comom occurance .
A friendly drop in cam for the RB25DET is Tomei's Poncams , lots of peoople have used them and I haven't seen too much negative feedback .
PM Woolverine , he's had the Hi Flow and the RB type GTRS .
A .
A .
The Gtir has totally different head castings too, the std turbo had a 0.86 and was woefully laggy and responded well to an upgrade (better response and better peak) im sure they used a 0.86 for some homoglamation (spelling?) rules as it was neither here nor there for results.
this graph shows a tuned 180sx vs a GTir tuned. (the 180sx makes more torque nearly everywhere)
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
