Item Summary: Team Dynamics ProRace 1.2 17x9 +35 UK made competition wheel
Condition: Used
Reason for Selling: Bought for EVO, won't clear front brembos without spacer
Asking Price: 1250
Delivery Methods: PickUp
Contact Info: PM or 0430945041
Extra Information:
I have a set of 4 Team Dynamics ProRace 1.2 rims for sale.
They were bought to replace the rims on my Evo VIII (as one of the rims is buckled and vibrates!) but these, interestly enough, wont quite clear my front calipers and a 8mm spacer would be required to clear the caliper. A mate of mine has these exact rims fitted to his Aus Delivered Evo 6 TME and I thought the brakes were the same - apparently not. As this is my daily driver, I do not feel comfortable with the 'legalities' or lack thereof of fitting a spacer.
Size and offset are 17x9 +35 5x114.3. Believe the rims weigh in just above 9kg each. Can get definite weights if necessary. Are used in the UK touring car series.
I would think these should clear GTR calipers. GTR has an extra 10mm backspacing on the rotor when compared to the evo. Assuming similar calipers dimensions this would mean they'd fit. Happy to test fit for local buyers, or take measurements from interstate buyers to determine fitment.
One rim has been removed from box for test fitting purposes. The other three have not left the boxes. As such, there are no marks to be seen.
Will include shipping to anywhere in Australia at the asking price of $1250.
Team Dynamics site can be found at http://www.teamdynamicsracing.com/index.htm
Sorry about quality of pictures, thank the iPhone and current low light conditions. Will get some better pics soon.
Will entertain offers for swaps for wheels of interest (that'll fit) plus cash either way.
17x8-17x9 +30-35ish, reasonably good condition (no major gutter graze). Reasonably light, no chromies need apply. Things like Weds, Enkei, gram light, work etc. Not chasing any 'advanti' or other chinese wheels. Don't really need tyres.
Cheers,
James.
Cheers,
James.
Need to move these, need new wheels for the car ASAP.
these should fit on an evo as stock evo8 wheels are 17x8 +38
these are 1" wider so thats 12mm on each side + 3mm on off set
so realistically they should extend 15mm~16mm to outer position (closer to the guards)
That is exactly what I thought, my mate has the exact same size and offset on his evo 6 TME. I was so confident infact i took the car down to a tyre fitter and told them to swap the tyres over from the current rims and balance and fit.
Luckily for me they had the intelligence to test fit.
I got a call from them about 15 mins later saying they had issues. Went back and had a look, definitely fouling.
should contact the company if you bought them new...
i would of been interested if it fits the evo... sigh
Yep, bought them new, would have to ship them back to NSW which is more out of pocket expense.
What evo do you have? I can tell you now they wont fit on my JDM 8. A mate has the exact same size and offset on his 6.5. He is the guy that actually recommended them to me. I think his brother may actually want them for his 7, and run spacer if necessary (its a race car, so doesn't need to worry about insurance liability etc) If they fit, I'd be using them. They are a well built good looking set of wheels.
id take a pair if anyone else will
That could work black200is. I could probably use a pair on the back of my MR2 race car for drag radials.
I'll give it a few more days and if there are no takers I might travel down this road if you are interested.
Cheers,
James.
Cheers,
James.
Price drop, $1150 SHIPPED to eastern states of Australia.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
