  • 1 month later...
  • Replies 48
Aiming for 250-280rwkw in a R33 gtst. (currently got around 200rwkw)
Will the R32 GTR fuel pump be good enough for this goal?
Is $125 a good price for a 2nd hand one?
thnx.
Currently have 265 rwkw using GTR pump, so should be OK.
Ok price:cheers:
at what point on a gts-t will the fuel pump need to be upgraded, and from there the injectors and regulator ???
i was wondering the same thing actually...benm said they are good for 300bhp or approx 180rwkw when this thread was started way back in the day...
i originally thought it was closer to 200rwkw or thereabouts many go over 180rwkw with the stock gtst pump and still get enough fuel...Could people with experience in this matter please confirm for me as currently with the 180rwkw fuel pump limit it means i will be close to or on the limit next week when it gets tuned for some more power. Just wondering if i should start thinking new fuel pump??
There is no absolute answer, it's not like a light switch, OK at 180 rwkw and not OK at 181 rwkw. It depends on soooooo many factors, how clean is the fuel filter, what voltage is the fuel pump seeing (do you have a big stereo that sucks power and lowers the voltage), have you improved the efficiency (cams for example) that mean you get more power out of each molecule of fuel, how good is the ring to bore seal, are the injectors clean )hows there spray pattern), how efficient is the turbo, the intercooler, the exhaust etc etc
So some people get 200 rwkw and some don't, and that's as good an answer as I can give:cheers:
Hi gtsii
I recently purchased a 044 for $360 brand new COD from an advertiser in these forums.
We installed it intank which was a bugger of a job - if I did it again I'd seriously consider mounting it externally - so much easier but I'm unsure on the legalities.
Make sure you install the check valve also as we didn't and it takes two clicks of the key to prime the fuel system enough to start in the morning.
It's nice and quiet though - certainly worth doing the job once and properly. Petrol stinks.
Good luck!
Glen
same reason i like the gtr pumps, straight fit and are quieter than the bosch's.
You can get them second hand or there's a place in Vic which sells them brand new for $440 each. I'm getting one and I think if we were to get them together we might be able to get them cheaper.
pm me if interested! :)
  • 5 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
