Rare Work Wheels 5x114.3 17x8 +5 17x9 +10, R33 Rocker Cover Gasket Kit, R33 Gtst Ngk Iridium Spark Plugs, R33 De-cat, R33 Gtst Front Brake Pads.
hey guys i just sold my r33 and don't need these parts anymore.
not sure on model of these but they are rare work wheels 17x8 +5 and 17x9 +10. rear tyres are gone but fronts can still be used 205/45r17. pretty decent condition considering age with jsut abit of gutter rash on 1 rear wheel: $1500ono
R33 gtst rocker cover gasket set with left and right rocker cover gaskets (RHS: 13270-58S11 LHS: 13270-58S01) and x5 half moon plugs (11051-58S00). bought new from nissan for $102.00 which is pretty much the same as the one from kudos motorsport: $90
New R33 GTST NGK Iridium spark plugs x6. model number is: BKR5EIX-11. Recommended for stock/ish r33s. could fit other models but check the ngk website first: $70
used R33 decat pipe which looks like a cat. has dent as seen on pic and one on the otherside in the same place. does not effect performance at all. 3" wide pipe: $60ono
New Maxxistop R33 front brake pads: $50
can post items at buyers cost and according to weight otherwise picup is in hoppers crossing, vic.
do not low ball me as some of these prices are pretty cheap already. call me on 0432454387.
thanks
yeh they kinda do but they aren't as work rezax have less spokes and are spread out more. plus these have "rs by elbe" on the centre caps.
i'm also gonna drop the price to $1200 as i need them gone now since i have got a 180 to pick up next week!
also price drop on:
gasket kit $80
iridiums $60
need this stuff gone guys!!
i also have a good condition standard turbo back exhaust that came from a gtst 33 series II minus cat. when i was putting an afermarket exhaust on on of the nuts rusted pretty bad and wouldnt come loose so the guy welded it off lol. can still be used but u'll have to reweld it btu tis not big deal. will let it go for $50firm
Edited by jakez88
pretty sure .. going by offset, sizes and spoke design
center caps are pretty generic thru all that type of rim from Work
pretty sure they are Work Stich Mesh
http://i142.photobucket.com/albums/r102/cr...e0031Medium.jpg
would fit awesome on a 5studded R31 coupe. great price.
been getting alot of offers for the wheels so i will bring the price down to $1100. do not pm me anything lower then that otherwise i'll just ignore it. first in get em.
should also say that the front tyres are potenza GIII's with 50% tread on them although one has a nail in it so they pretty much need new tyres all round unless ur willign to repair it.
$1000firm for the wheels!!!!!!!!!
need these gone by next week!!!!
Edited by jakez88
sorry guys. wheels are sold pending payment!
although i'll let you know what happens.
r33 gtst front brake pads still for sale~! $40
Edited by jakez88
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
