R32/r33 3' High Flow Cat, Genuine R33 Rear Strut Brace, R33 S2 Rear Seats, R33 Carbon Fibre Rear Bumper Heatshield [syd]
I have a few more things for sale, located in North Sydney
R33 genuine rear strut brace- $90
Genuine rear brace, a direct bolt on for R33 coupes
R32/33 Hiflow 3' Cat Converter- $100
Full stainless steel, bolt on for all R32 R33 and R34 GTR, and in good condition.
R33 Carbon Fibre Rear Bumper Exhaust Heatshield- $75
R33 GTST rear seats in good condition- $50
pickup only
PM me if interested
Edited by chiksluvit
I'm assumine the the carbon fibre bumper exhaust headshield wouldn't fit an R34. Would love to know where you got it from though.
cat sold
what's left for sale:
pickup only
Rear strut brace sold
adding front King Springs lows for R32 KDFL-101-SP - $60
and Apexi power intake pod filter in good condition, bolts on the RB25/20 AFM -$40
Not sure if the R33 GTR rear bumper's the same as the GTSt, it looks the same to me so i guess it should be ok.
One thing to note is that I've trial fitted it once, and I couldn't get it to fit properly because of the exhaust, I have apexi N1, and the exhaust tip didn't have much clearance from the rear bumper, plus it angles up, so it touches and I couldn't get it on properly, so you might want to double check on that too.
cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
