CHEAP R33 SKYLINE 1995 RB25DET 5 SPEED! 435HP @ WHEELS, MOTOR DOWN ON COMPRESSION, THOUSANDS $$$ WORTH OF MODS
Condition: Used
Reason for Selling: NO TIME TO FIX
Asking Price: 9500
Delivery Methods: PickUp
Contact Info: [email protected] 0418 537 181 or PM
Extra Information:
*This car is down on compression on 1st and 5th cyl, suspected ring or ringland problem. car still runds, idles and drives smooth. breathes heavy out of the cam covers*
1995 NISSAN R33 SKYLINE
RB25DET, 5 SPEED
car is stil regoed until the 7th month 2010
chassis has 161xxxkms
mods:
Engine:
forged pistons
eagle rods
total seal ring kit
head stud kit
main stud kit
cosmetic head gasket
ported head
550cc sard injectors
sard fuel pressure regulator
bosch 040 intank pump
Hardcore racing billet inlet plenum (rare)
100mm billet throttle body
garret gt35 .82 roller bearing turbo
external gate
stainless manifold with screamer
Z32 AFM
HKS Pod filter
turbosmart boost controller
Apexi Power FC with H/C
3.5" HKS Super Dragger exhaust
FMIC with stainless piping
driveline:
brand new exceddy button clutch
unknown mechanical diff
fresh pads front and rear
Suspension:
Aftermaket lowered springs and shocks (stiff)
front strut tower brace
Interior:
JVC touch screen DVD/TV
HKS boost gauge
HKS turbo Timer
Air Fuel ratio gauge
Mongoose alarm
rolling stock:
Nismo LM GT1 17x8 and 17x9 wheels (light and rare)
body:
paint is in good condition with only a couple of blemishes, front bar has recently been resprayed.
NO RUST
Sunroof, all work perfectly
all electrics work
Car itself is in good condition. Has had thousands spent on it! before this issue this engine made 435HP @ the wheels and would easily run 11sec passes with traction.
did a compression test last friday, 1st and 5th cyl are down on compression. will be ring or ringland failure. i just dont have the tiem to fix it so im selling it as is.
can also supply a fresh rb25det motor +rb25 box with this car for $3000. stocko unmodified low km motor purchased from Erin @ JDM Garage
selling for $9500 with rego. obviously no RWC
may also consider swaps
please call 0418 537 181 or pm
peace
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
