Hypergear Turbocharger High Flow And Overhaul Service, Best Price On Garrett Gt Turbochargers. .63/82 Oem Patterned Turbine Housing.
HyperGear Turbocharger high flow and overhaul services:
Australian Made Turbochargers that is made to bolt up to factory RB20/25det engines:
Information relating to profile, model updates, installations, dyno read outs and etc at are our discussion thread:
http://www.skylinesaustralia.com/forums/Hy...ce-t261613.html
All of our work and product supplied are covered with 12 month warranty (excluding engine oil related or object damage). for All high performance applications.
Please give us a call on 0413457185 or 0390163965 if any assistance is required.
Standard high flows are done by using factory housings and actuator.
R33 high flow maxes around 240rwkws
R34 high flows maxes at around 260rwkws.
UP high flows comes with larger .63 or .82 turbine housings with high pressure actuator.
They maxes around 280rwkws
SS high flows are made for fast response. They maxes at
230rwkws with R33 turbo housings (.63 PU upgrade turbine housings is available for 250rwkws applications)
250rwkws with R34 turbo housings
Photos of above are in our discussion thread.
Hey stAo how much to rebuild a hks 2835 pro s turbo for the r33 skyline I need new wheels, new cartridge and bearings?
Cheers
chi
Cheers
chi
  • 3 months later...
It will need brand new CHRA if wheels are broken. for a brand new Garret BB CHRA you will be looking around $1100. Or we can build you a sleeve bearing CHRA in idential spec for $800.
  • 3 months later...
how much for a gt3071 .63 external wastegate housing just the housing tao or can i use a block off plate? thanks
housing is $400 including machinery work and the Plate that blocks off the wastegate whole. I will need your turbo for a day.
  • 1 year later...
Hi there. I have a r34 gtt with garrett a/r .60 with the op6 rear exhaust houseing (ball bearing turbo) and i'm looking at making 250-260rwkw.
currently running std engine std manifolds splitfire coil packs stage 1 pom tom cams 3'' turbo back exhaust with 100 cell cat and free flow muf dumped at diff in a lc gtr torana. also fitted with 600x300x76 front mount bar n plate intercooler and a pod filter mounted down low at front to get nice cold air when driveing.
Was interested in you hiflow service for this turbo and need to know a few things
1 dose this include fitting of steel exhaust wheel
2 will it remain inturnal gated as std
3 will the std injectors 440cc feed this power level
4 how much all up and some contact info would be needed
Thanks Dave
Hi Dave:
Yes standard high flow will make around 260rwkws mark after high flowing on stock manifold. You will need a 3inch metal induction pipe for this sort of power level. Std injectors will max around 230rwkws, you will need 550ccs to get up to that power level.
The turbo will fit all factory bits excluding oil line after high flowing. The price is $960 including braided oil feeding line required and GST inclusive.
  • 3 weeks later...
For mid range it can go up to 24psi. Uptop it would be sitting around 18psi depending on the size of the rear housing its been worked on.
How do i find that out. It's an op6 r34 gtt turbo you did the std hiflow on it. and fitted steel wheels.
Then it should be a.63 rear housing. its fine holding about 18psi in upper rev range, you might need an high pressure actuator as stock might not be able to hold that much of back pressure.
  • 10 months later...
hey Stao, just wondering if an over haul can be done on an rb25NEO turbo? does it include a re-seal?
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
