Up for sale are a few items which came off my R33 S2 when it had 90k kms on the clock.
R33 S2 Fuel Pump - $80
Walbro 255LPH fuel pump - $100
R33 S2 Turbo with very minimal shaft play - $300
R33 S2 Turbo Blown, includes wastegate (just not pictured) - would suit a highflow - $50
R33 S2 springs and shocks - $130
Please pm me or call me on 0423 840 920, prices are neg, can post at buyers expense.
All items are located close to Menai, NSW
https://www.sau.com.au/forums/topic/313506-r33-s2-parts-stock-and-aftermarket/
Guys, I also have R33 S2 370CC Injectors for sale $100.
Forgot to add that the Walbro pump is only 7500kms old
Edited by da spike
  • 1 month later...
  • 2 months later...
