hey man how much power can it handle im in townsville by the way
exedy web site says>
Heavy duty Cushion Button Kits
Our Heavy Duty Cushion Button (HDCB suffix) clutch kits are recommended for use in moderately tuned vehicles that are driven on a daily basis.
This product utilises the positive aspects of an extremely durable ceramic material which has the capacity to transmit increased engine torque while maintaining a relatively comfortable engagement feeling attributed to the unique process of attaching the ceramic material to the clutch disc segment or marcel.
To complement these unique clutch discs, HDCB clutch kits are also supplied with high performance clutch cover assemblies with increased clamp loads.
web site link>>> http://www.exedy.com.au/CushionButtonClutchKit.aspx
  • 3 weeks later...
haven't got any pm's mate
i'll also send you one here :/
Do you have the con not number for the clutch, still hasnt arrived......ring me on my number that I sent to you
Clutch still has not arrived
If this clutch does not arrive by tomorrow or there is a reply to my PM's or threads on here I will take this further
Another Bump for this clutch still not delivered that was apparently posted the 21st of April
Edited by rb2534
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
    • I know on some cars it's explicitly endorsed in the service manual but a lot of them it isn't which is what gives me pause. I know a lot of cars also have you jack up the car by the radiator core support which is a lot easier to get to than some crazy deep section of the front subframe. I'm just reluctant to find out if any of that is really safe to do if not listed in the service manual. The FK8 has even the R-chassis beat in this regard, the front subframe jack point is almost fully behind the front tires and is surprisingly recessed into the car.
    • I've been doing it for longer then I can remember and on pretty much every car I've owned without any issues.  Jack on a tow point (or under the rear diff), jack stands under control arms/other beefy suspension component is my go to if I'm not using the quick jack.
