This was great!
Having all that johnny walker on the way down didnt hurt, and then to show up and see everyone on JD's?! AWESOME!!!
Very well run, and the video link thing was great, im sure these days will increase in poularity pretty quickly. It will be a shame if it turns into a wanker-wallet-sport like autosalon dyno comps though
Oh and Nathan? Better check out post 55 after seeing your car run :)
http://www.skylinesaustralia.com/forums/in...t&p=2583714
What was the final highest power figure on the night? (At your shop, not the national record, although that would be nice if you know it)
Well what can i say, what a great night. I'd like to thank all the people who came out and the great vibe you brought with you(except steve :ninja: ). It was great to see all the late nights paid off and people were willing to bring there cars out. It was the first time that a web-linked dyno day has been tried and there was potentially lots of things that can go wrong but there were relatively few problems. We learned alot from it and we're already planning the next one. Tomorrow night we're having a meeting to discuss ways to improve these days so if anyone has any ideas please let me know.
Edited by O2 Autosports
This was great!
Oh and Nathan? Better check out post 55 after seeing your car run :P
I don't think it will ever get too serious at our venue. The best bit about the night is that we all enjoyed it and i'll be trying my hardest to keep it like that in the future.
The highest power figure on the night at our venue was 471 hp. We'll hopefully have a few other builds finished for the next one that will eclipse that and your gtr. :ninja:
  • 1 month later...
  • 3 weeks later...
and it was a V8 :banana::ermm:
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
