as title states, i have a set of SSR Strusse wheels for sale, have freshly powder coated black centres, huge dish and would look insane on a stagea. follow link for pics and contact info
http://www.skylinesaustralia.com/forums/Sa...ml#entry5153488
https://www.sau.com.au/forums/topic/314533-ssr-strusse-19x10-19-19x11-11/
would look insane on a stagea.. if they would fit.
you won't get an 11+11 on the rear without a spacer to clear the struts, then you'd need wider guards to cover them
Not to
mention as soon as u drove atessa wd flip out!
why? just make sure you get the right tyre sizes to maintain the same rolling diameter front and back.
yeah people put different size tyres on the front and rear of stageas and awd skylines all the time, sure its not reccomended but its not like they have a locked centre diff. and im pretty sure they will fit, my quick offset maths says they will. but of course if someones interested id reccomend a test fitment first
what? no.
you have to maintain the same rolling diameter front and back or your ATESSA. This means the diameter of your wheels plus the tyres in the front have to be the same as the diameter of your wheels plus the tyres in the back. Tyre profiles are measured in percentages of their width, so when you run staggered widths, you have to make sure the profiles are still the same size.
use this to help you choose:
http://www.miata.net/garage/tirecalc.html
It is doable on a Stag with those wheels.
235/35/19 front and 275/30/19 rear and the rolling heights will be the closest you can get for staggered 19s. from memory, they're only 3mm apart
D.
currently has 245 35 19 and 275 30 19
  • 1 month later...
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
