Hey,
I'm putting my Tein CS coilovers for sale as they don't fit my manual S2 RS Four S. I haven't used them & they will arrive this week from Import Monster.
This is the roughly translated description from Import Monster:
Nissan Stagea (WGNC34) is an exhibition of CS type for the Tein. Been overhauled by the manufacturer. In that case, cutting short stroke (Ft-mm 10, Rr-35 mm), replace the piston rod, piston valve replacement, and I have a dust seal replacement. Spring rate of spring are now teamed Ft7.0k, Rr6.0k it. After OH distance is about 5,000 kilometers.
They come with the manual for the coilovers, as well as some stickers. I am not sure if they come with the Tein spanner to adjust the height. I will confirm that once they are delivered to me.
I am selling them for $1000.00.
I am located in Enoggera QLD, pickup is preferred. I can deliver in Brisbane or the Gold Coast in the next week. Freight for people interstate is up to you to organise.
Any questions, please drop me a PM.
Cheers,
Adam
https://www.sau.com.au/forums/topic/314979-tein-cs-coilovers-for-sale-1000/
